Old 12-16-2017, 08:10 PM   #1
roh1332
roh1332's Avatar
Default Throttle return spring replacement
Took a bit but found a post that recommended removing floor board to get to the throttle control assembly. Good choice. My question is this, how do you replace the throttle return spring? It appears that everything is fixed. But I’m sure something must come apart to replace the spring. Does anyone know how to disassemble the throttle control assembly to be able to replace the spring?
File Type: jpg 1EFDA4B1-7FCF-4F3C-9822-26BD1C9E8AAA.jpg (67.3 KB, 285 views)
roh1332 is offline   Reply With Quote
Old 12-16-2017, 08:22 PM   #2
glenn in camino
glenn in camino's Avatar
Default Re: Throttle return spring replacement
Thread it on and wind it up to tension and slip it on the arm.
glenn in camino is offline   Reply With Quote
Old 12-16-2017, 08:33 PM   #3
Big hammer
A real pain, its been awhile, I think stretch and twist it over the obstacle ? Mount in a vice helps, hand you can use both hands.
get a bigger hammer tap done
Old 12-16-2017, 09:18 PM   #4
roh1332
roh1332's Avatar
Do I ask how to take off the old one?
Old 12-16-2017, 09:57 PM   #5
Don Turley
Don Turley's Avatar
There were several styles of throttle control assemblies. To replace the spring on the style shown in your photo requires that you remove the arm that the spring hooks on. There is a drive pin through the boss on the arm that holds it to the shaft. Once you remove the pin and arm, replace the spring and reassemble. Note, since there is more than one style of throttle control assembly, there is also more than one style of spring. Be sure you purchase the correct spring for your assembly.
Don Turley is offline   Reply With Quote
Old 12-16-2017, 10:04 PM   #6
1955cj5
1955cj5's Avatar
Bratton's replacement spring comes with a replacement pin as Don mentions...
https://www.brattons.com/28-april-30...pring-pin.html
I have the other style and it uses a different spring...
Neat pickup! Tell us more about it....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 12-16-2017, 10:13 PM   #7
1955cj5
1955cj5's Avatar
You already have the floor boards out. You will probably have to remove the linkage assembly...
There are two bolts that pass through the throttle linkage, through the flywheel housing and into the block, accessed from the cab, under the fuel tank.
Be careful when you remove these bolts as there probably are some brass horse shoe shaped shims between the block and flywheel housing. They may fall out...
You will need to replace these shims when reassembling in the same position that they were in originally....
You can see the bolts and the shims in this picture...no throttle linkage yet of course....
Old 12-16-2017, 10:53 PM   #8
roh1332
roh1332's Avatar
I’m having a hard time finding the pin. How hard is it to remove and how would you remove it? Punch?
Old 12-16-2017, 11:06 PM   #9
1955cj5
1955cj5's Avatar
It must be there...it might have been peened over and would be hard to see. If it's peened you may have to file the end a bit then drive it out with a punch.
Keep track of the orientation of the arms for reassembly....
Go to http://www.fordgarage.com and search throttle linkage...you will find pictures...I can't copy/paste with this laptop...
Old 12-16-2017, 11:31 PM   #10
roh1332
roh1332's Avatar
Would you say the dot in the red circle area?
File Type: jpg 771175A5-7414-4C11-B441-9D3108E2BE80.jpg (26.5 KB, 255 views)
Old 12-16-2017, 11:53 PM   #11
1955cj5
1955cj5's Avatar
That must be it.....
Old 12-17-2017, 12:54 AM   #12
roh1332
roh1332's Avatar
I don’t see anything. Even grinded it down and still nothing.
Old 12-17-2017, 01:08 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I would have wire brushed it.
Maybe a drop of oil, then heating it will help show the pin.
Old 12-17-2017, 09:26 AM   #14
jhowes
I have the mid 30 type that seems to be bent into shape. How on earth do you get it apart, there is no boss with a pin just a bent arm as far as I can tell. Jack
jhowes is offline   Reply With Quote
Old 12-17-2017, 01:44 PM   #15
roh1332
roh1332's Avatar
Tried to twist it over, and all I’m doing is bending the spring.
Old 12-18-2017, 10:27 PM   #16
roh1332
roh1332's Avatar
Well I found it. Wire brushed made it show. Very lightly. The pin was a softer metal than the throttle assembly. Would not budge with punch and five pound hammer. Drilled small hole through the pin and then it came loose with punch. Thanks again for your help everyone. Very much appreciated. Here’s a few pics if you like to keep for reference. Hopefully this post will help someone in the future. First pic shows the pin after the wire brush. The second is after I got the pin out and removed the arm. And the third is it all back together.
File Type: jpg A9F2C4E3-49DF-4595-8ACE-024570ED9029.jpg (70.8 KB, 253 views)
File Type: jpg 51B6138B-FEEE-4386-8386-A6F67A935CCC.jpg (66.0 KB, 239 views)
File Type: jpg C356022A-80EB-4FAF-A01F-5FDCE6924BB0.jpg (55.7 KB, 235 views)
Old 12-19-2017, 06:07 AM   #17
Bruce of MN
Bruce of MN's Avatar
Good photos, the first one shows the pin well.
Bruce of MN is offline   Reply With Quote
Old 12-19-2017, 07:29 AM   #18
Ray in La Mesa
Kool, glad to see the result.
Ray in La Mesa is offline   Reply With Quote
Old 12-19-2017, 12:19 PM   #19
Ernie Vitucci
Good Morning...If you don't wish to take everything apart, there is a second non stock way to add spring tension. One can mount a small pad eye on the wooden floor board behind the throttle connection at the carburetor and then run a small spring from the hardware store from the pad eye to the throttle connection. This is a $10 repair that I have used a few times. I usually also shoot the original throttle spring with break cleaner and put oil in the two friction bearing holes. This little modification has worked well on several cars as you can adjust the tension by changing the small spring which is only 3 inches + or -. Ernie
Ernie Vitucci is offline   Reply With Quote
Old 04-24-2022, 04:57 PM   #20
charlesatto
charlesatto is offline   Reply With Quote
Thread Tools
Display Modes
