05-29-2023, 05:18 PM | #1 |
Modern distributor spark advance
Do you have to switch to a 12 volt system to install a distributor where I don't have to constantly fool with the spark advance. If not who is selling these. Do you still have to set the point's or is it electronic.
05-29-2023, 05:37 PM | #2 |
Re: Modern distributor spark advance
05-29-2023, 05:54 PM | #3 |
FSI ignitions of Oklahoma makes an electronic distributor with centrifugal advance and no points for both 6v and 12v. I use one without any problems.
Tom in Texas 1931 Coupe |
05-29-2023, 09:39 PM | #4 |
The F S I is a nice unit, pretty much a plug and play, I have one in operation at the present , I got a smokin good deal on it from a person who never got around to install it, I also in the past have done my own conversions from Japanese car dist's , I had the Japanese car and installed a new dist. shortly before it was totaled and put he dist. back on the shelf and forgot about it till a few months ago , after a re -curve the converted dist is awesome as well . P.M me and I'll see if I can find the part number, it is a fairly simple and cost effective conversion , if you have access to a small bench lathe it can be done in about a half hour.
05-29-2023, 10:50 PM | #5 |
There is also the nu-rex automatic advance unit that goes in the valve cover area.
This way you can keep the stock dist. but have it automatically advance. You can use a pertonix ignition module if you want to make it electronic ignition. Snyders carries them. |
05-30-2023, 01:54 PM | #6 |
05-30-2023, 02:10 PM | #7 |
Give FS ignitions a call. They’re out of Ponca city, Oklahoma I believe. Get a better deal buying direct and if you have any issues at all they will stay on the phone and help you work everything out. I bought the Zipper distributor from them. I had the poor guy on the phone for over an hour going through everything and it all turned out to be a fuel flow problem. I’ve been running the distributor for almost a year now and it’s been wonderful. Here in Arkansas I’m in the Ozarks. Lots of hills and it’s nice not having to fiddle with the spark rod.
05-31-2023, 02:49 PM | #8 |
[QUOTE=Shiloh;2229826]Give FS ignitions a call.
YES!! It's been 3 years now. Just be sure it's got a good ground |
05-31-2023, 04:05 PM | #9 |
Mine has the electronic ignition but no auto advance. I'm thinking of adding the NuRex advance. I also carry a rebuilt point distributor pre timed in case the electronic fails.
06-02-2023, 07:53 AM | #10 |
Nu-Rex, was the way for me.
Regards Bill |
06-02-2023, 12:38 PM | #11 |
Dan, why do you have to constantly fool with the spark advance? Do you have a high compression head? Stock Model A's (4.22:1 compression) run with the advance at the 9:00 position after initial startup, unless climbing a significant hill. The hill might require a notch or so of retard depending on what exact position the ignition was timed at.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
06-04-2023, 01:16 PM | #12 |
I have a Mallory Dual Point that has auto advance, and a Model B Distributor (which also fits Model A) which has auto advance. I’ll sell either one for $150 + shipping
