Old 05-30-2022, 06:52 PM   #1
Steve007
Default 1940 ford chrome lever and switch plate
Hello, need to change my switch plate for my ignition on my 40 but first need to remove the chrome lever. Is the lever screwed on or is there a set screw I'm not seeing. Or does it come off another way? I know this is probably trivial to Ford guys but I haven't had this car very long and am learning most things by myself. Any and all help would be appreciated! Thank you!
Steve007 is offline   Reply With Quote
Old 05-30-2022, 07:44 PM   #2
JayChicago
JayChicago's Avatar
Default Re: 1940 ford chrome lever and switch plate
Deleted. After seeing the next reply, realized I misunderstood the original question.
JayChicago is offline   Reply With Quote
Old 05-30-2022, 08:06 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
No, not screwed on. It’s on a splined shaft. I used a staple puller to lever it up.
File Type: jpeg DEBCFBF4-201F-4007-B477-32527203A02C.jpeg (81.0 KB, 52 views)
File Type: jpeg 9A9CE0A3-2F97-4E1A-8134-816B03B6E309.jpeg (120.4 KB, 40 views)
Ken/Alabama is offline   Reply With Quote
Old 05-30-2022, 08:12 PM   #4
MGG
MGG's Avatar
A trick I use is to wrap a thin piece of electrical (or any kind) of tape around the perimeter of the switch before removing the two screws which hold it on. This enables you to get the unit to your work bench where you can disassemble it on your terms rather than pick up the pieces off of the floorboard. To reinstall it, reverse the process, removing the tape after the two screws are in and snug.
MGG is offline   Reply With Quote
Old 05-31-2022, 05:19 PM   #5
19Fordy
19Fordy's Avatar
QUESTION: When prying that lever UP and OFF is there any chance of that spline shaft breaking?
Is it malleable steel or cast metal?
Old 05-31-2022, 08:25 PM   #6
Ken/Alabama
It’s cast but what other options do you have ? Do not twist it !
Old 05-31-2022, 09:51 PM   #7
Steve007
Update on lever removal. Got the chrome lever off today. Got a wood shim like you would use on a door in your house. Put it under the lever and used a screwdriver to pry it off. It came off really easy which surprised me. Now I can install the new switch plate and the the chrome lever. Thanks to all that had information on this!
Old 06-01-2022, 09:01 AM   #8
19Fordy
19Fordy's Avatar
That's great news Steve. Well done.
