Old 12-01-2021, 09:25 AM   #1
Model A Ron
Model A Ron's Avatar
Default Decided against Tires.....what about this idea?
I decided against original bias ply black wall tires and would like to go with the new American Classic white wall Radial tires.
Is anyone running the radials?
What are your thoughts on looks and performance?
Model A Ron is offline   Reply With Quote
Old 12-01-2021, 01:18 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Decided against Tires.....what about this idea?
Do a SEARCH as this has been discussed countless times. Any NEW tire will be good, bias or radial.
Many positive reports on the American Classic's.
Paul in CT
Old 12-01-2021, 03:01 PM   #3
nkaminar
nkaminar's Avatar
Discussed in depth on other threads. Search for American Classics. I will say that I installed a set on 19 inch whitewalls on my car recently and like them. I use regular innertubes but others recommend innertubes approved for radial tire.
Old 12-01-2021, 03:14 PM   #4
Anteek29
Anteek29's Avatar
Personally, I'd go for the radials with whites.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 12-01-2021, 03:34 PM   #5
Ordsgt
Ordsgt's Avatar
expensive but I put 5 on my car and after almost 1500 miles I love them. Used regular tubes
Ordsgt is offline   Reply With Quote
Old 12-01-2021, 04:31 PM   #6
Model A Ron
Last time I looked they were $30 more per tire for the radials.
Old 12-01-2021, 06:25 PM   #7
gdmn852
gdmn852's Avatar
Hello, discussion on radial tires in State of things: 21" radials post although as says for 21 inch tires.
gdmn852 is offline   Reply With Quote
Old 12-01-2021, 07:40 PM   #8
TerryO
TerryO's Avatar
Yes...Love them...
TOB
TerryO is offline   Reply With Quote
Old 12-02-2021, 11:58 PM   #9
Model A Ron
Do the radials look any different?
Old 12-03-2021, 02:51 PM   #10
redmodelt
redmodelt's Avatar
When I read the title, I was expecting to see some novel idea about replacement tires, like plywood or something along those lines! LOL Considering the current supplier issues. "Decided against Tires....." !
Old 12-03-2021, 04:34 PM   #11
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Yes, me to. Thought he had re invented the wheel- - - - er “tire”.
Old 12-03-2021, 11:47 PM   #12
Model A Ron
It was a play on "Decided against Turn Signals" So basically click bate to get some opinions on radials
Old 12-04-2021, 01:18 AM   #13
SHEC
SHEC's Avatar
Sorry....call me old fashioned but Blackwell tires on all Model A’s for me. I am really particular when it comes to pickups and whitewalls.... I know, I know...to each his own.
SHEC is offline   Reply With Quote
Old 12-04-2021, 05:46 PM   #14
ronn
I am with you shec. also, havent seen a radial that "looks" right to me.
some are close.........
Old 12-04-2021, 07:41 PM   #15
History
History's Avatar
There are cars that whitewalls are appropriate, most would look better with black walls IMO. Opinions are varied.
History is offline   Reply With Quote
Old 12-05-2021, 01:58 AM   #16
Model A Ron
I respect your opinion on black walls and I know they were original to the Model A. The problem to me is that White Walls make the Model A pop and if Henry was not so cheep they would have been original equipment in my opinion. To each there own.
Old 12-05-2021, 07:32 AM   #17
History
History's Avatar
The car in your avatar is one of the appropriate cars, it looks great!
Old 12-05-2021, 08:45 AM   #18
nkaminar
nkaminar's Avatar
As you know, the sidewalls on radials flex more than bias ply tires. One of the concerns is over heating the tubes because of the increased flexing. I just got back from a Christmas lunch for my HCCA club yesterday (one hour at 55-60 mph) and felt the sidewalls. I have a heavy 1930 Fordor with a trunk full of tools and spare parts in the back. My rear tires wear more than the front because they carry more weight. When I got back the rears were warm to the touch and the front tires were just above room temperature.
I have pumped up all four tires (American Classic) to 40 psi and the sidewalls are still flexing like radials do. I am going to pump up the rears to 45 psi. The 35 psi that Ford recommended for the tires was based on bias ply tires. In my opinion the radials should have more pressure. The goal for me is to have the radials perform like radials but not have them overheat or wear too rapidly. So I am looking for the right pressure to reach that goal.
Old 12-05-2021, 09:10 PM   #19
Model A Ron
Anyone else play around with higher PSI on Radial tires?
Old 12-05-2021, 10:28 PM   #20
40 Deluxe
I imagine tire engineers might know a thing or two about proper inflation pressures for their radial tires. At the very least, check the sidewall data for maximum pressures. (And then don't exceed that pressure!)
