Old 08-17-2017, 01:54 PM   #1
Gary WA
Gary WA's Avatar
Default Fender brackets front
28-29 front fender brackets, is there a left and right or both the same?29 sport coupe
www.whidbeymodelaclub.com
Old 08-17-2017, 02:14 PM   #2
RawhideKid
Default Re: Fender brackets front
No, the fender brackets are swapable. And depending on what month, were either forged or stamped.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 08-17-2017, 02:43 PM   #3
wrndln
Front fender brackets were forged in 1928. The forged front brackets were carried over into early 1929 for many assembly plants. My early 1929 phaeton has forged front brackets and stamped rear fender brackets.
Rusty Nelson
Old 08-17-2017, 05:54 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Dog here,
I'll add this to my TRIVIA info, to RECOMEMBER---I'll ask Vermin whut he has????-- In case he goes fur High Points---His fenders still have them little GROOVIES, whar the edge wire were rolled in, even!!! We HATE to sell him, but Ol' Bill's gettin' too OLD to drive him SAFELY & I cain't reach the PEDALS & we need the MONEY for Dog Food!
Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 08-17-2017, 07:58 PM   #5
glenn in camino
glenn in camino's Avatar
They are the same and usually need to be bent to fit the fender.
Old 08-18-2017, 09:22 AM   #6
BILL WILLIAMSON
Glenn,
Ted used a BIG ROSEBUD torch, to "shape" his He does the same, on CROOKEDY Running Board Brackets
Bill W.
Old 08-18-2017, 04:24 PM   #7
Gary WA
Gary WA's Avatar
Thanks all must be bent not lining up with fender bolt hole they are forged.
Old 08-18-2017, 04:53 PM   #8
wrndln
You can bend the forged brackets without fear of breaking them, unlike the cast repros that will break easily. They can be bent cold or with heat. I once straightened out a forged rear coupe bracket that look like a horseshoe (must have been in an accident) to align it with an unbend bracket I had.
Rusty Nelson
Old 08-18-2017, 05:22 PM   #9
BILL WILLIAMSON
Rusty Nelson
Rusty,
I "think" I saw you, as a Blacksmith, in an OLD Western Movie---CAIN'T remember the movie title
Bill Brokenshoe
Old 08-18-2017, 07:05 PM   #10
PatrickGrant
PatrickGrant's Avatar
Rusty,
I just straighten one, to fit your fender, with my torch. I left it cool on its own because I was worried about tempering it. Didn't want to try bending it cold, but I would like to see how they bend on a junk one sometime. Pat
PatrickGrant is offline   Reply With Quote
Old 08-18-2017, 10:18 PM   #11
Randy in ca
Randy in ca's Avatar
Gary, there were also forged front fender brackets used in 1930. If things are off more than a little this could be the problem. It's easy to tell them apart by the shape where they attach to the frame - post a picture if there's any doubt about which you have.
Randy in ca is offline   Reply With Quote
Old 08-19-2017, 09:02 AM   #12
100IH
Also, the distance from the mount at the bottom to the two holes for the fender are different.
100IH is offline   Reply With Quote
Old 08-19-2017, 09:54 AM   #13
wrndln
I am attaching a picture of some forged 1930 front fender brackets I have. Note the bosses for the larger bottom bolts - the lower boss is the same thickness as the top 2 bolts. 28/29 forged brackets have a much thicker lower boss - sorry I don't have a picture handy of the 28/29 bottom area of the brackets. Some time I will take a picture of the two together to easily show the differences.
Rusty Nelson
File Type: jpg Front fender brackets forged - 1930 ends.jpg (38.7 KB, 40 views)
Old 08-19-2017, 11:14 AM   #14
vern hodgson
Rusty Nelson
I did bend these brackets to fit, fore and aft, the only fit now is the outer fender hole is a little off (high) will need to work on that, no breaking. Must not be remakes.
vern hodgson is offline   Reply With Quote
Old 08-19-2017, 11:26 AM   #15
wrndln
Don't forget to insert the 2 headlight bar bolts through the fender and bracket holes. I got the outer fender carriage bolt to fit in one of my vehicles, but the headlight bar would not fit due to the bracket holes being off 1/4" to 5/16".
Actually I have 6 or 8 front brackets, so to easy the pain of fitting and bending them, I try different ones until I get a close fit. I don't know what I will do when I get down to the last few brackets for my 4th vehicle and only have two or three left, I guess I will have to start bending them.
Rusty Nelson
Old 08-19-2017, 07:55 PM   #16
vern hodgson
Rusty Nelson
Right, and I also kept bracket to frame bolts loose until all was fit up.
Old 08-19-2017, 08:53 PM   #17
Gary WA
Gary WA's Avatar
Good job Vern Ready to start it up!!??
