Old 08-12-2013, 07:46 PM   #1
Ten1nis
Ten1nis's Avatar
Default Grinding noise
When taking a sweeping turn in my"29 Sport Coupe I hear a metal against metal rubbing noise, only when there is a lateral force, never when driving in a straight line. Sounds like the brake drum against the backing plate or against the brake shoe. Could the axle nut be not tight enough. I torqued it to 125 ft/lb.
Ten1nis is offline   Reply With Quote
Old 08-12-2013, 07:56 PM   #2
Gary Karr
Gary Karr's Avatar
Default Re: Grinding noise
It sounds like your rear drum(s) are rubbing against the backing plate as you suggest. A simple fix is to install an axle shim(s) on the end of the axles. They can be purchased or better yet, you can make them yourself from a tin can!
Gary Karr is offline   Reply With Quote
Old 08-12-2013, 08:20 PM   #3
Bob C
If it's the front could be loose bearings.
Bob
Old 08-13-2013, 07:20 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I would remove the rear brake drums and see what's scraping. Bert's gave me a brake drum when I was there buying parts. The inside has a groove almost worn through to the outside of the drum. This was caused by the parking brake rubbing on the brake drum.
Old 08-13-2013, 07:59 AM   #5
Jim/GA
Jim/GA's Avatar
Yes, take each drum off and look for the shiny one where it is rubbing the backing plate or something else.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
