Old 08-08-2013, 10:49 AM   #1
Ten1nis
Ten1nis's Avatar
Default Paint or Powder Coat?
Should I spend the money powder coating my '28 Sport Coupe's wheels? The wheels currently look good painted, but I understand the durability of the powder coat is far better. Your thoughts?
Ten1nis is offline   Reply With Quote
Old 08-08-2013, 10:57 AM   #2
Mitch//pa
Default Re: Paint or Powder Coat?
powder coat without a doubt.....
Old 08-08-2013, 11:34 AM   #3
bogdonj
bogdonj's Avatar
Powder Coat! Very happy with mine over the years!
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 08-08-2013, 12:32 PM   #4
Bill Underwood
But don't expect to tough them up very easily. At least that has been my experience. Also, I've seen the lugs snap powder coat....paint too!
Bill Underwood is offline   Reply With Quote
Old 08-08-2013, 12:34 PM   #5
denis4x4
denis4x4's Avatar
Powder painted 15 years ago and still look good. Same goes for the hairpins. Powder paint is your friend!
denis4x4 is offline   Reply With Quote
Old 08-08-2013, 01:11 PM   #6
gweilbaker
gweilbaker's Avatar
Powder coat but clean the lug chamfers.
gweilbaker is offline   Reply With Quote
Old 08-08-2013, 01:31 PM   #7
Rock Hornbuckle
Rock Hornbuckle's Avatar
Powder coating is absoluely the best.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 08-08-2013, 01:49 PM   #8
1967gt
1967gt's Avatar
if it aint broke dont fix it !!!
1967gt is offline   Reply With Quote
Old 08-08-2013, 02:00 PM   #9
P.S.
Excellent point.
Putting some grease on the lug nuts where they contact the wheel before putting them on will solve that. And, don't exceed the recommended torque.
P.S. is offline   Reply With Quote
Old 08-08-2013, 02:06 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
I've seen some beautiful powder coated wheels and they are tough, but when the time comes, I'm going to spray paint mine.
Old 08-08-2013, 04:05 PM   #11
whirnot
whirnot's Avatar
I powder coated mine and then bought the stainless washers to protect the wheel from the lug nuts. Would do it again.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 08-08-2013, 04:13 PM   #12
sconnors
sconnors's Avatar
I painted mine, put nickels in the lug holes prior to priming and painting they came out great!
sconnors is offline   Reply With Quote
Old 08-08-2013, 04:34 PM   #13
jkeesey
jkeesey's Avatar
Im going to powder coat mine since I just found a shop that does it for a very low price compared to most.
jkeesey is offline   Reply With Quote
Old 08-08-2013, 08:01 PM   #14
antiquepa
antiquepa's Avatar
Powder Coat, but if u do what ever the wheels look like, if pitted will show, so if the wheels are smooth when u powder coat they will look good. Don't know if they can smooth out any wheels before they powder coat, but when I had mine done they were really nice wheels. Don"t forget to use the stainless steel washers for the lugs, will keep them from chipping. Very Durable, as far as im concerned its the only way to go!!
antiquepa is offline   Reply With Quote
Old 08-08-2013, 08:24 PM   #15
QGolden
QGolden's Avatar
You wont regret the Powder coat. Just ask a lot of questions at the shop. When you walk away with your wheels left behind, be confident they know how to prep. The quality of the job is all prep. Proper prep is the most expensive and labor consuming part of the job. Laying the powder is easy.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 08-08-2013, 08:44 PM   #16
Colonel
What is the proper prep for the powder coat?
Colonel is offline   Reply With Quote
Old 08-08-2013, 09:28 PM   #17
swo4rd
swo4rd's Avatar
watch that pc shop does not build up particularly at joints of spokes with rims and hubs...it is not authentic and it looks awful.
Painting is, I believe, Best.
Swoff
swo4rd is offline   Reply With Quote
Old 08-08-2013, 10:16 PM   #18
Brother Hesekiel
Brother Hesekiel's Avatar
I can assure you that there was no powder coating in the late 1920s, so unless you are building a rod, you should stick with what was used when your car was built. I personally don't even use powder coat on motorcycle frames, as any chip can allow humidity to crawl underneath and create havoc.
Brother Hesekiel is offline   Reply With Quote
Old 08-08-2013, 10:33 PM   #19
QGolden
QGolden's Avatar
Any chip will allow any coating to fail. Prep is the key. Here is a link to a Feb post where this was discussed.
http://www.fordbarn.com/forum/showthread.php?p=589187
Old 08-08-2013, 11:23 PM   #20
colin1928
colin1928's Avatar
I would powder coat them
colin1928 is offline   Reply With Quote
