06-02-2013, 11:10 AM | #1 |
Engine locks up with Oil Pan Install
I reinstalled my oil pad today & after I had all the bolts tightened I tried to turn the engine over with the hand crank. It wouldn't budge.
I had this problem before I took the pan off also. I did have the car running when I got it & before I started to do anything to the engine. After sitting for about 2 months while I worked on the body the engine wouldn't turn with the crank. That is why I removed the head & oil pan. Originally it started to turn easily as soon as I removed the oil pump. This time I tried to turn it as I was removing bolts from the pan. Still frozen after removing left side bolts. I left the center left on to hold up the pan After removing right side bolts & letting pan drop slightly I could turn it over I removed the pan & pushed the pump up by hand & it would turn over. Seems to be a connection between the oil pump & not turning over. The pin on the pump is in the hole in the block & it pushes up flush with the bottom of the block. Any ideas? |
06-02-2013, 11:13 AM | #2 |
Re: Engine locks up with Oil Pan Install
your spring is intact on the bottom of the oil pump isnt it?
1929 Model AA - Need long splash aprons! |
06-02-2013, 11:18 AM | #3 |
I think your distributor is seized.
06-02-2013, 11:18 AM | #4 |
Yes spring is on pump
06-02-2013, 11:19 AM | #5 |
Distributor is removed
06-02-2013, 11:51 AM | #6 |
Pictures of my oil pump |
06-02-2013, 12:26 PM | #7 |
Is this a fresh rebuild? I've seen some fresh rebuilds that are very stiff to turn with the hand crank, but the electric starter cranked the engine over fine. Once the engine gets a few hours use, it should be easy to hand crank. My friend had a fresh rebuild and when I was dialing in the flywheel cover I had a hard time getting the crank to turn with the hand crank. Once the crankshaft was turning it was much easier to keep it turning, but after the crank was left untouched for a few minutes it was again stiff to get moving.
06-02-2013, 12:37 PM | #8 |
Operator Error (I think)
I put a new round gasket in the front of the oil pan with the 2 side gaskets. Looking back underneath there is already a round (appears to be rubber of some kind) gasket there so I was trying to use 2 gaskets. I removed the oil pump to try without to see if it fit & couldn't get the pan up all the way in the front. Looked closer with a light & saw the there gasket. I thought the pan was hard to put up because of the pump spring. Will reinstall pump & try again. Why do the pan side gaskets need to go on the block instead of the pan? I have the rubber like gaskets in the front & back of the block & don't see any way to tuck the side gasket tabs behind the gaskets |
06-02-2013, 07:17 PM | #9 |
Show a pic of your oil pan. Is the baffle pushed down completely in place ? Maybe the crank is comming against if it's not in place.
06-03-2013, 10:17 PM | #10 |
Did you find out anything on your oil pan problem ?
06-03-2013, 10:47 PM | #11 | |
06-07-2013, 03:06 PM | #12 |
Final Status:
The oil pan fits fine with the oil pump installed. The engine turns over with the hand crank without problems. I have the head installed & torqued down. I have to clean up some hardware & then its ready for the body to go back on. Body is at painters & should be ready in about 2 weeks. Still lots of parts to clean the smoke film from. During this lull I can get back to some of my other projects. |
06-07-2013, 10:07 PM | #13 |
I think you guys missed his post, he is trying to squeeze two front seals in. The car has modern rubber seal and he was trying to install a rope seal also because he didn't know about the modern rubber seal.
The rear seal is made longer then needed. You need to trim it some. I would change that rear rubber seal to the cork type if you have one, they are a real bear to install under the car. The rear seal come in two different widths. Make sure the one you have fits in the slot so it's just held in. |
