04-07-2013, 02:06 PM | #1 |
New engine
We got a new engine .....
Fired it up - first time today First (short) ride was BAD Some adjustments later, 2nd ride was WAY better Its running smooth (even its new) and provides LOTS of power Still lots of work to do. |
04-07-2013, 02:19 PM | #2 |
Re: New engine
Very nice!
www.whidbeymodelaclub.com |
04-07-2013, 02:26 PM | #3 |
Re: New engine
Ya das ist gut.
Also I am glad to know that I am not the only guy on the whole planet that has a kink in his spark adjust rod. |
04-07-2013, 03:06 PM | #4 | |
Re: New engine
the bent spark rod is an OK temporary farmer fix, but eventually the steering column should be rotated so everything lines up correctly with the rod straight. see the procedure on Marco's web site......
our next Model A is out there in the unknown...... |
04-07-2013, 03:44 PM | #5 |
Re: New engine
The engine and compartment look very nice.
I see you insulated the first spark plug strap, so you are probably using a timing light. Last edited by Tom Wesenberg; 04-07-2013 at 06:36 PM. |
04-07-2013, 04:04 PM | #6 |
Re: New engine
"no one knows more than everyone" |
04-07-2013, 04:41 PM | #7 |
Re: New engine
Looks great. The new engines get better with more runs. Have fun with it.
Fred Kroon 1929 Std Coupe 1929 Huckster |
04-07-2013, 05:28 PM | #8 |
Re: New engine
ZOOM ZOOM> Very nice looking !! Babbitt??
Paul in CT |
04-07-2013, 07:38 PM | #9 |
Re: New engine
Looks good. Don't forget to retorque the head to 55 lbs..
04-07-2013, 07:41 PM | #10 |
Re: New engine
Very good looking power plant.
04-08-2013, 01:42 AM | #11 |
Re: New engine
Looks Great Christoph !!!!!
Now you should be ready for the long Summer trips you have planed. Was it one from the USA or is it the old engine that you rebuilt ? any modifications ? John Cochran |
04-08-2013, 02:57 AM | #12 |
Re: New engine
OK, what happened on the first ride?
04-08-2013, 04:54 AM | #13 |
Re: New engine
Thank you for your comments
Original engine ist still running but tired. Took it out of the car and stored it propper (hopefully) New engine is a rebuilt of an old engine Its got inserts, oil pressure, is counterbalanced and has 5,5-head (shame on me) Excuse: no one over here to do (payable) rebabbits and US-Vendors dont have overseas warranty ( Scruple is gone once using 2nd rearlight, fuses and 3:54axle ) But it has to be a driver as we want to drive even more than we did last year. First start was somewhat bumpy It stalled often till i found out that - manifolds not tightened - sparks without propper clearence (no 2 had contact) I did shout the mechanic to be an idiot (which was me) Full floating engine now (chances to use engine-pans in future??) Once driving, there are strange speed related noises (going off the throttle) Got to find out about (Noises are still arround if im "out of gear" so its not the engine). Additional there are slight noises from leakless waterpump area (might a new leakless have a bad bearing???) Thought there might be comments regarding oil-pipe to the camshaft.. No?? Ja - Tom i know that you got sharp eyes and you are right I thought you would comment the oil-caps on the starter too Sorry to state that i did not know regarding kink in spark-rod as i (back in time) bought the first A i ever saw running Not to many Pre-War-cars left over here .... I DO LIKE THE KINK Change will be priority : c BTW I have thisRadius-ball using the rubber-ball I do not need springs anymore?? How strong to tighten nuts? Ball still should be able to move inside ?? Effects of full floating-engine? Did anyone ever change back to any reason?? Please come back with ideas. No club nor other A arround - Got to learn from you... Thank you Greetings Christoph Head is retightened allready. Engine went about : 15 hours on a bench (electrical driven) and about 15 hours on a bench (under own power) |
04-08-2013, 05:28 AM | #14 |
Re: New engine
Chris looks like a 7 tooth column, so he will not be able to rotate it.
04-08-2013, 05:32 AM | #15 |
Re: New engine
Nice neat oil filter arrangement. Where is the oil return line going?
04-08-2013, 05:55 AM | #16 |
Re: New engine
George
Good to learn about steering - didnt know it 7-tooth Thank you Lots of oil-pressure now Feeding the inserts through the drilled crankshaft and feeding the camshaft on its front (would you in US do that too??) My Engine-Guru stated that the engine looked (before rebuilding it) somewhat dry in that area and he didnt like.... He stated that some Splash-engines will splash less than others Might have changed after 80 years or so... Hopefully i will need 20 years to tell you whether that was a good idea. |
04-08-2013, 06:38 AM | #17 | |
Re: New engine
04-08-2013, 07:12 AM | #18 |
Re: New engine
Well - wurks - actually we did.
Guru said he did his own A 20 years ago and engine still is powerfull... Got to trust him. Would be great to have pre-drilled holes in the counterbalanced crankshafts Just drill throug surface (in case you need the oil-lines), and thats it... How do you feed inserts?? |
04-08-2013, 08:30 AM | #19 |
Re: New engine
Deiner motor ist viele schoen! ( I think that's correct?) Anyway, Very nice! So many distractions come along while we're working, Phone rings, dog barks, who knows! We sometimes forget to tighten something. It can be really bad when you're working on an airplane. It happens all the time. Just check, check, and recheck! (But don't take too long)
Terry |
04-08-2013, 08:45 AM | #20 |
Re: New engine
Take it down the autobahn and see if the Polizei can keep up!!!
