Old 07-03-2014, 04:02 PM   #1
56servi
56servi's Avatar
Default Any Hubcap Tab Repair
I have 3 hubcaps (10 tab style) that most of the tabs are missing & the ones left are about to fall off. Is there any other way to mount the hubcaps on the wheel. This is going on a driver. 2 are for the spares & one for a wheel on the car. I do have a couple of the tabs that broke off
56servi is offline   Reply With Quote
Old 07-03-2014, 04:44 PM   #2
MikeK
MikeK's Avatar
Default Re: Any Hubcap Tab Repair
Dirty fix: Make three cuts (red lines) with a dremel cutoff wheel. Bend up, cut narrower with tin snips, shape as tab. Wear gloves when using that dremel cutoff wheel handheld and close. Your fingers will thank you.
MikeK is offline   Reply With Quote
Old 07-03-2014, 04:55 PM   #3
56servi
56servi's Avatar
Will try this
Thanks
Gene
Old 07-03-2014, 08:04 PM   #4
tbirdtbird
never bend up all the tabs, not needed. Just bend 3, since you know they will eventually break off, then u use the others
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-03-2014, 09:05 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I have always bent all the tabs enough for the hubcap to snap in tight, then bend over 2 inside the hub ---2 to keep it on, the rest keep the hubcap from rattling
To replace "lost" tabs I have used a stud gun ---dent pulling studs spot welded each side of a missing tab
Old 07-04-2014, 05:32 PM   #6
flatford39
Silicone maybe???
flatford39 is offline   Reply With Quote
