02-04-2022, 10:40 AM | #1 |
Hubcap ID help please :)
Any help identifying these would be greatly appreciated. Thanks in advance men
02-04-2022, 11:02 AM | #2 |
Re: Hubcap ID help please :)
Top middle is 54 car
Top right is late is 52-53 car Not sure on the rest. Is bottom right from a Plymouth? |
02-04-2022, 11:05 AM | #3 |
Top row L to R: '46 Mercury, '54, 53
Not sure enough on the others |
02-04-2022, 11:19 AM | #4 |
Thanks guys. I knew you guys could help. We're getting there!
Oh, yep, I snuck a Plymouth cap in there
02-04-2022, 11:24 AM | #5 |
Is the center right one smooth from outer edge to the center bullet? If so, then 49-50 passenger car. If not, maybe aftermarket repop of same?
Center one is mid to late 50s "poverty" cap from when full covers were common. A site I found says 1956, but I can't verify that. I'm no help on the Mercury and Plymouth units. |
02-04-2022, 11:26 AM | #6 |
Bottom right is '50 Plymouth. Last edited by Road Trip; 02-04-2022 at 11:27 AM. Reason: Added info. |
02-04-2022, 11:27 AM | #7 |
Second row center is 1956 and the one to the right is 49-50, bottom row first one is 1961-62 Mercury and I think it is correct for some of the mercury trucks.
02-04-2022, 11:07 PM | #8 |
center one looks like '57 Ford. center right '51 Ford, maybe!
02-05-2022, 12:52 AM | #9 | |
Yup,, second row-center is '55 and '56 Ford
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
02-05-2022, 09:13 AM | #10 |
02-05-2022, 11:37 AM | #11 |
Center row left is '50 Olds.
02-05-2022, 01:02 PM | #12 |
Center row right looks like what was on our 1950 Ford sedan. Bottom row left was what was on our 1965 Mercury Comet.
02-05-2022, 06:22 PM | #13 |
Identification of Hubcaps are Left to Right - Top Row 46 Mercury, 54 Ford, 53 Ford. Middle Row 54 Oldsmobile, 56 Ford and 49/50 Ford - Bottom Row 62/63 Mercury Meteor and Plymouth. Regards Mercman <>< |
02-05-2022, 06:59 PM | #14 |
With regards to the 1952 - 1953 - 1954 Ford Hubcaps, they are all different. On the 52 Hubcap, the FORD lettering is on a slant. On the 53 and 54 Hubcap, the lettering is vertical and is the same for both years, but the indent for painting the centre of the 54 Hubcap has been added. Note, that Ford Australia painted the Centres Black, while in the USA, they were painted Red. For detail, check out the above photos. |
02-12-2022, 04:19 PM | #15 |
Thanks a ton you guys! I am obliged to you all for the help.
