Old 11-15-2017, 10:03 PM   #1
JunkyJud
Default Offenhauser 3 carb intake and Stomberg 97's
City: Seneca
State: PA
Price: 1000.00
For sale is an Offenhauser 3 x 2 intake with 3 Stromberg 97's. **The engine is not for sale, it is only being used to hold the intake for photos**
This was removed from a 49-53 Merc that developed a cracked cylinder about 10 - 15 years ago. I bought it this way with the bad engine and have never ran it myself. It has been stored inside and was drained of fuel at that time. The carburetors were rebuilt at some point and have progressive linkage that operates smoothly. The throttle shafts have been re-bushed and extended shafts installed for the linkage. All of the threads in the intake are in good shape and there are no cracks or damage. Everything operates freely. The carbs appear to have clear coated bodies. One choke plate is in place on the center carb and the others have been removed and the shaft holes blocked. Only the center accelerator pump is connected. The alternator mount is also included as well as the fuel pressure regulator, gauge, and stainless lines.
The price is $1000.00 plus shipping from zip 16346. The box will weigh about 35 lbs. and will be 24" x 15" x 12" if you want to get an idea of shipping yourself. PM me with any questions.
JunkyJud is offline   Reply With Quote
Old 11-19-2017, 08:31 AM   #2
JunkyJud
Default Re: Offenhauser 3 carb intake and Stomberg 97's
