Old 08-24-2021, 07:37 PM   #21
JRShaw
JRShaw's Avatar
Smile Re: opinions on 'lifts'
QUESTION - Gentlemen: Does this lift require an air compressor outfit?? This point is not clear from either the television advertisements nor the little "clip" above. Thank You in Advance.
JRShaw is offline   Reply With Quote
Old 08-24-2021, 07:39 PM   #22
wmarcy528
Default Re: opinions on 'lifts'
Electric power with hydraulics
wmarcy528 is offline   Reply With Quote
Old 08-24-2021, 09:26 PM   #23
slatgrille
slatgrille's Avatar
It requires you to pressurize two small cylinders adjacent to the larger hydraulic cylinders with 40-50 psi from an air compressor. Other than that, mine runs on 110v to activate the hydraulics. You can get it with 220v or 12v as an option I think.
slatgrille is offline   Reply With Quote
