Old 01-20-2022, 12:11 AM   #1
Duke
Default Machine later gears for 1934 axle
I would like to go to a 3.78 or 3.54 to replace the 4.11 in my 1934 axle. I have to shorten my driveshaft so that is not a concern (going in a 32). Is the machine work on a set of 1940 3.78 worth the time? Has anyone done this and know the number of hours vs new gears at $595?
Duke is offline   Reply With Quote
Old 01-20-2022, 01:07 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Machine later gears for 1934 axle
1938-40 gears have a 6 spline pinion.You need to find a set of 35-36 10 spline . If its 3.78 you have to have the pinion gear bearing surface machined to use the 33-34 pinion bearings.35 and later pinion bearings will not fit in the 33-34 banjo(to large) If its 3.54 the top of the 11 tooth pinion gear will have to be machined (to fit thru the banjo opening)as well as the pinion bearing surface. Finding a good used set of 3.54's is not easy. In 1968 I had a 35 3.54 pinion fitted to a 34 banjo by Cook's Machine in L.A. They also shortened the driveshaft(necessary). $20 back then.The ring gear will not need to be machined.Last set of true 33-34 3.54's I saw for sale was $750 and that was awhile ago.
Here is a thread on the HAMB
https://www.jalopyjournal.com/forum/...ar-end.672981/
deuce lover is offline   Reply With Quote
Old 01-20-2022, 02:22 AM   #3
bobH
As Sheldon is aware, I did this same job in 08, 10-spline 3.78 from a 37 Ford, into a 34 banjo. My experience was the same as his. At that time the guy that did the crankshaft grinding at Johnson Machine in Monrovia CA, did the pinion modification. He was a flathead guy, and knew exactly what to do, including the slight step on the pinion bearing surface. I don't recall what I paid for machine work, but I remember it was dirt cheap, I'm thinking $25. I already had the gears, bearings, etc, so the total job was very inexpensive. The driveshaft shop charged very little, also.
bobH is offline   Reply With Quote
Old 01-20-2022, 06:38 AM   #4
Elmo Rodge
Elmo Rodge's Avatar
Bobh, that guy was Howard (his last name escapes me at the moment). Allen?
Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 01-20-2022, 07:00 AM   #5
Lawrie
Lawrie's Avatar
If you have access to a lathe its an easy job, I have done quite a few, use an insert tool to turn the pinion bearing down to the 33/34 size,(copy the old 33/34 pinion dimensions) use the same insert tool to machine the tips of the pinion teeth to just slip into the 33/34 housing,(no more) use an oil stone to debut the teeth after this, make a spacer to take up the difference in pinion bearings under the pinion nuts,( I think about 1/2 inch) let me know if you want the exact dimensions, bore the inside of the 10 spline on the 33/34 drive shaftto allow a tap fit of a 6 spline coupler cut in half and weld it intaking care to drill the retaining pin hole in the right place,
Lawrie
Lawrie is offline   Reply With Quote
Old 01-20-2022, 07:09 AM   #6
Terry,OH
Terry,OH's Avatar
Worth the $595 of new gears. It is most likely a break even or a monetary loss. It is a lot of fun and rewarding.
Old 01-20-2022, 12:47 PM   #7
solidaxle
solidaxle's Avatar
Do you have the 3:78's or do you need to buy them? If I were you I would base my decision on performance not price. Depending on your tire size and transmission and weight, the 3:54's my be better suited for your car.
solidaxle is offline   Reply With Quote
Old 01-20-2022, 12:54 PM   #8
cas3
I did it about 5 years ago. Local crank grinder did the pinion for 50 bucks, then I did the drive shaft myself. The ring gear tips do not always have to be trimmed, mine did not, but some do. Only worth it because I had the 3.78's in stock, and could do the drive shaft myself.
cas3 is online now   Reply With Quote
Old 01-20-2022, 08:56 PM   #9
Duke
Thank you everyone for the help, especially Deuce Lover who phoned from France to help me.
I currently only have 4.11 gears. I can find later Ford 3.78 easily vs the cost of a new set of 3.54.
Old 01-23-2022, 07:01 PM   #10
Dennis Mielke
There was an article in the early ford v8 club magazine some years back explaining what to do and how to do it.
Dennis Mielke is offline   Reply With Quote
Old 01-24-2022, 12:31 AM   #11
Lawrie
Lawrie's Avatar
PM me if you want a step by step how to
Lawrie
