03-29-2023, 02:56 PM | #1 |
1930 CCPU Door Hinges How to Install
Starting to put together a basket case 30 CCPU. As I look at the door edge I am trying to understand how to attach the hinges. I see three holes instead of something to thread the screws into. I was going to install lock washers and nuts inside the door but it looks that might interfere with the window channels? Possibly use a lock nut.
I have searched here and have not been able to find anything that explains how to deal with this. Any help would be appreciated. Photos would be helpful also. I did notice there are two holes at the top hinge and there appears to be a nut that has been welded into the skin of the door edge for one of the screws. |
03-29-2023, 03:49 PM | #2 |
Re: 1930 CCPU Door Hinges How to Install
The hinges are riveted to the door.
04-04-2023, 09:11 PM | #3 |
Three special short little countersunk bolts thread thru the door post into those hinges. The screws are unique to the later Model A hinges. New ones are available. Part number A-48590 on modelastore.com
04-06-2023, 04:26 PM | #4 |
