Old 11-13-2023, 12:52 PM   #1
mac101
Default Water pump
I rebuilt my water pump and installed it using the new bolts that are machined to look like the original studs and nuts, doing this I didn’t have to pull the radiator. I have a leak coming from the top left bolt. These studs are threaded all the way to the nut. Is it possible the leak is around the threads?
mac101 is offline   Reply With Quote
Old 11-13-2023, 01:23 PM   #2
Big hammer
Default Re: Water pump
Yes , there a couple of through holes in the head that will leak, drain the coolant remove the look alike studs and seal the threads that go into the head, refill with coolant
get a bigger hammer tap done
Old 11-13-2023, 01:29 PM   #3
TerryO
TerryO's Avatar
The upper left hole goes into the water jacket...like B H said remove that bolt and seal it...problem solved...
TOB
TerryO is offline   Reply With Quote
Old 11-13-2023, 06:08 PM   #4
mcflash
Live and learn...
mcflash is offline   Reply With Quote
