02-21-2024, 02:53 PM | #1 |
Need Id on rear window garnish
Need some help on years make (Ford or Mercury probably ?) and models for this rear window garnish it measures 14 5/8 " tall and 33 1/4" wide The center piece is fixed and not removeable like some. Thanks in advance
02-21-2024, 03:25 PM | #2 |
Re: Need Id on rear window garnish
Looks like one for a 1939 Mercury Coupe, I can verify in about 2 hours or so when I get home from work!!!
02-21-2024, 03:35 PM | #3 | |
02-21-2024, 06:42 PM | #4 |
Bistingear
I can’t upload the photos off my phone as the image is too big and will post in the morning from my work computer, until then the measurements are as follows, the widist point is 37”, the width at the center divider is 13-7/16” and the widist part of each glass opening is about 16-3/4ish 16-7/8ish wide!!! Again will post pictures first thing in the morning!!! looks just like mine!!! 1939 Mercury Sedan Coupe IF the measurements match!!! |
02-21-2024, 08:06 PM | #5 |
ok this is only 33.25" wide
02-22-2024, 07:51 AM | #6 |
Just to make sure you and I are/were measuring from the same locations. Maybe 39 Ford since its narrower |
02-22-2024, 08:29 AM | #7 |
ok thanks 39 ford it is
02-22-2024, 08:37 AM | #8 |
02-22-2024, 10:27 AM | #9 |
The one that fits my 1937 coupe is 13.25” tall by 36.25” wide, same as rockfla’s dimensions.
02-22-2024, 11:54 AM | #10 |
