06-07-2021, 07:48 PM | #1 |
Parts Unknown
Found. Any insight is greatly appreciated. I assume the T wrench is a lug wrench. It has "C.C.M." stamped in several places and is 6 point x 1". The Wells switch is NIB. The condensor?? is unknown condition, it's in what appears to be its original box.
Thanks. Tom |
06-07-2021, 08:01 PM | #2 |
Re: Parts Unknown
I doubt the wrench is a lug wrench due to the short handle. The condenser and the switch are both aftermarket items, and are clearly identified on the boxes.
Alan |
06-07-2021, 11:00 PM | #3 |
Re: Parts Unknown
That wrench is a fancy-dancy, early-days sparking plug wrench! And the condenser is '32-'36 Ford right on the box. DD |
06-08-2021, 03:13 AM | #4 |
Re: Parts Unknown
With respect to Coops I don't think the wrench is for spark plugs as it does not appear to have enough hollow area to clear a plug. What size is it a/f?
06-08-2021, 07:24 AM | #5 | |
Re: Parts Unknown
(as posted in #1 above)
06-08-2021, 07:30 AM | #6 |
Re: Parts Unknown
06-08-2021, 10:34 AM | #7 |
Re: Parts Unknown
Wasn't "CCM" a brand of hockey skates?
06-08-2021, 02:14 PM | #8 |
Re: Parts Unknown
Got to thinking about the T wrench. I pulled a plug out of the '32 engine and compared it to the wrench. It does not fit inside either by length or socket size. C.C.M. is rather crudely stamped in 5 different places begging the question was this perhaps the initials of the original owner? My Grandfather was a pipefitter during WWll at the Bremerton shipyard then later at Hanford Nuclear site, retiring in the '70's. Was this perhaps a special wrench used in industrial pipe fitting that he somehow ended up with? This tool has been there for as long as I can remember and I was born in '58. I don't ever remember my Dad using it. The mystery remains.....
06-08-2021, 03:09 PM | #9 |
Re: Parts Unknown
What is no mystery is that any condenser that old should never go on a car that you expect to drive further than from one side of the museum to the other. It might pass a capacitance test cold, but is quite likely to fail after a few heat cycles.
06-09-2021, 11:21 AM | #10 |
Re: Parts Unknown
CCM has made bicycles in Canada for many years
06-10-2021, 10:07 AM | #11 |
Re: Parts Unknown
06-10-2021, 11:54 AM | #12 | |
Re: Parts Unknown
I just can't picture a 1"-sized nut anywhere on a bike. DD |
06-10-2021, 12:08 PM | #13 |
Re: Parts Unknown
06-10-2021, 02:40 PM | #14 |
Re: Parts Unknown
The largest nut on a ccm bike is the wheel axle nuts that are 15mm.
Sometimes, ingenuity gets in the way of sense and sanity. |
06-10-2021, 03:06 PM | #15 |
Re: Parts Unknown
Yeah, what I thought....somewhere between 9/16" and 5/8". DD
