Old 06-07-2021, 09:01 AM   #1
RickMcK
Default 36 steering gear adjustment?
I rebuilt my 36 steering gear (new bearings, worm, selector...). I tried to adjust it per the instructions in the green service manual, but I can't seem to get the play correct.
I set the end play, then adjust the eccentric nut with the wheels straight. The gear box is sloppy turning to the left and tight to the right. If I adjust the eccentric nut so it's OK to the right, it's realy sloppy to the left. The eccentric (screw driver) adjustment does not seem to help the "to the left sloppiness.
What am I doing wrong? Any thoughts or ideas?
Thanks
Rick McKenney
Seattle WA
RickMcK is offline   Reply With Quote
Old 06-07-2021, 09:36 AM   #2
glennpm
glennpm's Avatar
Default Re: 36 steering gear adjustment?
Did you remove the Pitman arm or drag link. If not do so.
You probably have the attached. correctly setup, the tightest position is in the middle, straight down the road position.
File Type: pdf Steering Gear Adjustment 1932-1936.pdf (377.4 KB, 58 views)
Old 06-07-2021, 11:01 AM   #3
RickMcK
I removed the drag link. I will try again and see if I can get it to be correct.
Thanks
Rick McKenney
Seattle WA
Old 06-07-2021, 11:04 AM   #4
glennpm
glennpm's Avatar
Yes, disconnecting the drag link is best. It allows you to see and feel the movement of your adjustments.
Old 06-07-2021, 10:48 PM   #5
bbrocksr
You can only adjust it straight ahead. The slop on the right and left is in the design,
Center the box and adjust it snug, no bind that's all you can do.
Then center the box and adjust the drag link until the wheels are straight ahead. The box needs to be centered when you're going straight down the road and there will be very little play, Don' worry about the slack to the left and right their designed that way,
Bill
bbrocksr is offline   Reply With Quote
Old 06-08-2021, 10:01 PM   #6
johndee138
johndee138's Avatar
Swap it for a 37 and up box. HUGE improvement and essentially undetectable.
I did mine and it was night and day better.
johndee138 is offline   Reply With Quote
Old 06-08-2021, 10:35 PM   #7
Steve in Denver
Steve in Denver's Avatar
Did you have to remove the exhaust manifolds to remove your '36 steering box and install the '37 box? I understand that one can either drill additional holes in the '36 mounting plate or just install a '37 mounting plate.
Steve in Denver is offline   Reply With Quote
Old 06-09-2021, 04:24 AM   #8
Tom-MI
Tom-MI's Avatar
Steve-
You can't just redrill the '36 box (top hole) and simply add the '37 box. If you go this route you won't be able to get your exhaust manifold back on. The only way to do this is to replace the '36 frame plate with a '37 plate. This is not a 5 minute task. The '36 plate has a hidden rivet on the bottom side of the top frame rail which is a bear to get out.
Tom
Tom-MI is offline   Reply With Quote
Old 06-09-2021, 07:06 AM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
All the '35-'36 steering box mounting brackets that I've removed were riveted to frame in four places plus one spot weld at top of bracket to frame rail. This spot weld can be a bugger to get loose. I've had pretty good luck with twisting the bracket back and forth, side to side to break that spot weld.
John
Old 06-09-2021, 10:41 AM   #10
rottenron36
rottenron36's Avatar
I have a36 pickup and want to keep the 36 box. I know the 37 and up box is better. I just want to make my 36 box work as good as possible, I can live with that. I'm sure some of the barners have kept there 36 box and have some tips and tricks to sort them out. Thanks Ron
rottenron36 is offline   Reply With Quote
Old 06-10-2021, 10:37 AM   #11
32phil
One important factor on the early boxes is to follow the instructions to the letter in the EXACT order they say.
If you do things out of sequence it can change the outcome and how the box performs.
Each adjustment has an effect on the succeeding adjustment and if you go out of order it changes everything and you get the strange results you are seeing.
I found out the hard (long) way on several 32-34 boxes I did a while back.
Make sure you have a steering wheel installed too, as the weight (rotating mass)of the wheel makes the box "feel" different. Kinda like a flywheel on an engine.
You "think' you can go back to a previous adjustment and "touch it up a little".
NOPE... it will change the whole thing and you have to start over.
Also make sure any mating surfaces are clean and move freely against one another.
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
