Old 02-02-2021, 01:33 PM   #1
56MAN
Default 56' Power Seat Problem
My power seat just stopped working. When I try to raise or lower it I just get a clicking noise from the relay for that motor. When I try foreword or backward I get the same clicking noise from the relay for that motor. I removed both motors and bench tested them bypassing the relays and they worked fine. Should I assume that replacing the relays will fix the problem? I will appreciate any input. Thanks!!
56MAN is offline   Reply With Quote
Old 02-02-2021, 01:42 PM   #2
KULTULZ
KULTULZ's Avatar
Post Re: 56' Power Seat Problem
Bypass the relay(s) - TESTING ONLY
Might also be the switch. Isolate each from the circuit briefly.
Do you have a multi-tester?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 02-02-2021, 01:52 PM   #3
56MAN
Default Re: 56' Power Seat Problem
I did check the switch with a multi-tester and it is in working order. So the switch works, the motors work without the relays.
Old 02-02-2021, 02:55 PM   #4
Merc Cruzer
Merc Cruzer's Avatar
It really sounds like the relay, since you have tested the motors out of the car. I get the same issue, when the battery, is low on my 53' Merc, with factory 4 way seats. The relay will test fine, but they really need allot of power.
Merc Cruzer is offline   Reply With Quote
Old 02-02-2021, 05:40 PM   #5
KULTULZ
KULTULZ's Avatar
Good 'ol GEN and 6V Systems. I hated those things.
- WHY IS IT ... -
Old 02-02-2021, 05:56 PM   #6
delco1946
delco1946's Avatar
I have Merc Cruisers same issue with one of my windows, barely will move when idling but works much better on the highway when the generator is producing more volts. I already took the motor apart and cleaned it. I wonder where is a good source for (quality) relays?
delco1946 is offline   Reply With Quote
Old 02-02-2021, 07:13 PM   #7
KULTULZ
KULTULZ's Avatar
Exclamation Re: 56' Power Seat Problem
Squeeze your sphincters gentlemen before clicking on URL -
1955 FORD PS RELAY - B5A 14512-B - NOS
https://www.ebay.com/itm/NOS-1955-Fo...-/292790779912
- WHY IS IT ... -
Old 02-02-2021, 07:58 PM   #8
miker98038
miker98038's Avatar
Put the multi meter on and check the voltage in place under load. Probably need another person to do it. Sometimes things read ok with no load, but have enough internal resistant to not work under full load. I've had several failing batteries that read ok till you hit the starter and headlights. Not that I think that's your problem, but load does sometimes tell a different story.
If you can live with a non stock replacement.
https://www.classictbird.com/Relay-P...ctinfo/14512B/
miker98038 is offline   Reply With Quote
Old 02-02-2021, 08:58 PM   #9
Merc Cruzer
Take the cover off of the relay, by bending the tabs back, really carefully. If you break a few, the cover will still stay on. I usually spray a little WD-40 Contact Cleaner on the points, and it seams to do the trick. Considering the option (the cost of a new relay - ouch ouch ouch!). The old parts are really quite hardy, and in most cases with a little cleaning they can be put back into service.
Old 02-02-2021, 09:04 PM   #10
Merc Cruzer
I will be interested to see if cleaning the points, works for you.
Old 02-03-2021, 10:37 AM   #11
54vicky
54vicky's Avatar
this is good idea I have done the same on relays if the points are not to badly pitted in that case I clean with a piece of emory cloth (fine)then spray brake cleaner to remove residue
54vicky is offline   Reply With Quote
Old 02-03-2021, 11:14 AM   #12
54vicky
54vicky's Avatar
searching the part number there is less pricey one listed I say that tongue in cheek.at those prices I would look at modifying a horn relay
Old 02-03-2021, 12:05 PM   #13
BillCook
Send a message via Yahoo to BillCook
Well I’d go to 12 sys ,just change the bulbs ,all the motors will work fine with 12 V ,lower amperage ,since 6V motors have heavy wiring ,it will work fine I have 52 Fd all elec Mtrs and solenoids work great 15 yrs no problems !
BillCook is offline   Reply With Quote
Old 02-03-2021, 12:06 PM   #14
56MAN
Thankyou everybody for the great suggestions! I am new to this Forum as of a few days ago. I am impressed with the response I've received from my question. I will check the voltage under load and take relay cover off and clean contacts. I will report back with my results. Thanks again!!
Old 02-03-2021, 12:10 PM   #15
delco1946
delco1946's Avatar
Dear lord - i'll try to clean my relay, too at that price....especially considering how many I have that could go bad!
Old 02-03-2021, 12:35 PM   #16
KULTULZ
KULTULZ's Avatar
I would think that a person willing to pay that price is involved in a complete restoration and has to have everything correct down to the last detail.
Repairing/restoring these cars depends entirely how one is going to use it.
- WHY IS IT ... -
Old 02-05-2021, 07:10 PM   #17
56MAN
I have an update on my power seats not working. I checked the voltage at each post of the switch under load and got 10 volts. I then took the relays apart and lightly cleaned the contact points, and sprayed them with electrical cleaner. I got the same results. the relays just click. I ordered 2 new relays (which are on back order) and after I get and install them I will post the results. Thanks again to all who have responded with your knowledge!
Old 02-05-2021, 08:30 PM   #18
Merc Cruzer
Are you using 6 volt motors and relays with a 12 volt system?
Old 02-05-2021, 11:18 PM   #19
miker98038
miker98038's Avatar
A 56 Ford/Merc should be 12 volts. 10 volts under load might not manage a seat relay, I've never checked. If you've got 12 volts at the switch, and 10 under load, try running a long wire from the battery to the relay and see if it closes and holds. If you're losing 2 volts (12 in 10 out) at the switch under load, you might be even lower at the relay. Old connections, etc. Doesn't take much loss and the relay will click but not hold.
Old 02-06-2021, 03:54 AM   #20
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 56' Power Seat Problem
Good advice.
It may also be the seat track is in a bind or worn and is loading the motor(s) Maybe have to disassemble and lubricate track(s).
Also a charging system check, battery check (min 12V) and a load draw test on the seat motors while installed in the track.
- WHY IS IT ... -
