01-30-2021, 10:48 AM | #1 |
Timing with light and vacuum gauge questions
63 f100 292 y block, stock 2 barrel autolite - stock distributor, pertronix 2 ignitor and coil
I know the dampener may slip so I have a timing sticker to put on. 1)How would I go about getting this on correctly if the dampener has slipped? I'm assuming put #1 at TDC and lining up the 0 mark on sticker to the point. Once I find my zero mark, to set base timing I plug my dizzy vacuum diaphragm and the vacuum line that went to it. Start the engine. With timing light on #1 plug wire, I line up my advance. I've heard these engines like about 28-32 total advance, but without the diaphragm vacuum for advance connected, I'm assuming I'm only setting the base advance and have to add in whatever the dizzy advance is to make total advance, correct? So I've seen people set about 13-16 advance at this point. Then rev the engine to about 3-3500 to get the total advance and turn the dizzy to set the total. If I'm using a timing light with an advance gauge, I set the gauge to say 16 degrees, hit the button, and line up the 0 mark. 2) what's the point of setting base timing if I'm going to change it later with total? Unless this is more for changing the springs if equipped? Now I've also heard to set the timing without a light and just use a gauge. For y blocks some where around 20-25hg vacuum. I have a set of gauges I use for motorcycles to balance them at idle. Using one of the 4 should work. 3) Where would I connect it to, the dizzy diaphragm or the line that goes to the diaphragm? 4) do I ever connect the vacuum line to the dizzy when checking the timing at any of the above mentioned points? Sent from my Pixel 3 XL using Tapatalk |
01-30-2021, 01:44 PM | #2 |
Re: Timing with light and vacuum gauge questions
Here's a link explaining vacuum timing for anyone Interested. Also explains setting the mixture screws with a vacuum gauge.
https://automotivemileposts.com/gara...%20the%20gauge. Sent from my Pixel 3 XL using Tapatalk |
01-30-2021, 02:53 PM | #3 | |
As for now, you can set the timing with a vacuum gauge (if the valve lash/timing is correct and you have good steady manifold vacuum). You merely advance the DIST (with vacuum advance signal plugged off) until reaching the highest reading and then back it off a little. Drive and see if there is any pre-ignition/hard start. Same for balancing a CARB, highest vacuum reading achieved. As for advance, mech or vacuum, component integrity is a must and the curves must be matched to vehicle use (or OEM). Then you can go fancy,
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
01-31-2021, 10:10 AM | #4 |
as tool said you need to start with a good damper.it is like building a house with no foundation.if you have never seen the damage that a damper coming off.if it moved there is a reason.
01-31-2021, 04:00 PM | #5 |
Doesn't look like the dampener has moved. #1 is at tdc when the 0 lines up.
02-01-2021, 04:01 AM | #6 |
02-01-2021, 08:11 AM | #7 | |
Ideally, the DIST should be put on a DIST MACHINE to come to the best curve. It can be done with a timing tape, tach and light but the Y-BLOCK dist being @ the rear of the engine will work you to death. I would be hesitant to power time until I knew the condition of the DIST. Also be good to confirm correct manifold vacuum (vacuum leak - valve timing - fuel curve). Then plot manifold vacuum using a gauge while driving the vehicle.
02-01-2021, 08:17 AM | #8 | |
Now all of this is for one wanting top performance from the engine, whether OEM or HP. Otherwise, one would depend on OEM settings.
02-01-2021, 10:31 AM | #9 |
Well I have a new dizzy as well. Will look into a tdc stop. Nothing high performance wise. Getting a tach hooked up today. Timing with a vacuum gauge as well.
02-01-2021, 12:07 PM | #10 |
You have a new DIST (aftermarket or a rebuilt)? If rebuilt, what is the PN on it? Have you returned the OEM DIST for core charge yet?
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 02-01-2021 at 12:22 PM. |
02-01-2021, 02:06 PM | #11 | ||
Depending on the style and source of your replacement distributor, it may be the wrong one to fit the engine. Some of the auto parts 'exchange' distributors are rebuilt using core distributors that are not from a Y-block. The main shafts are too short and don't engage the drive gear on the camshaft or the oil pump drive correctly. If this is the case, distributor damage is certain and engine failure can also result. This photo shows the correct length of a Y-block distributor shaft. A few thousandths under 5 inches from the shoulder to the bottom of the driven gear, and one inch of shaft below the gear, to engage the oil pump drive. If the one you have now does not measure the same, return it ASAP. . Last edited by dmsfrr; 02-01-2021 at 03:07 PM. |
02-01-2021, 02:21 PM | #12 |
I have what I believe is the stock one (currently installed) and a new aftermarket. Working on setting valves right now. Was told to set them at .019. was also told to set them at .020 cold as the .019 is the spec when warm.
When I've set valves on older bikes it's always cold. Not warmed up. Also there are locking nuts on the adjuster bolts. I only have an adjuster bolt not locking nut. Is this normal? They're tight to turn so wasn't sure. Once I get the valves set correctly, I'll be putting in the new dizzy. It's a knock off msd one. Wanted to see how it would perform first, before I did anything with the stock one. Sent from my Pixel 3 XL using Tapatalk |
02-01-2021, 02:23 PM | #13 | |
02-01-2021, 02:36 PM | #14 | |
The ones with lock nuts and a screwdriver slot on the adjusting screw are the earlier version. The self-locking ones are the later version. Also check the casting number on the upper side of each rocker arm. There look to be four different types and a high performance version with an ECG prefix. http://ford-y-block.com/rockerarm.htm http://ford-y-block.com/technical.htm . Last edited by dmsfrr; 02-01-2021 at 06:26 PM. |
02-01-2021, 03:49 PM | #15 |
Yea I have the bottom ones shown for the rockers.
From bottom of new dizzy shaft to the worm gear is .971. now there's a raised portion around the gear in the center. If we're talking teeth of the gear then .988. From seat to gear teeth (from where the .988 ended) I have 4.933. unless you include that lip mentioned earlier but I suspect not. Thoughts on those measurements? Sent from my Pixel 3 XL using Tapatalk |
02-01-2021, 06:16 PM | #16 |
Went on to timing an tuning. Keeping rpms around 500-600, adjust the distributor to about 20lbs vacuum, then dropped it a lb. Turn mix screws all the way in then backed out 1.5 turns. Proceeded to turn them in until vacuum wouldn't raise any more, then backed off about an 1/8 turn dropping vac about .5lb. checked where they were at which is about .75 turns. Is that normal for them to be turned in so much?
Turning out richens right? Sent from my Pixel 3 XL using Tapatalk |
02-01-2021, 06:59 PM | #17 | |
The 'exchange' distributors that are built on the wrong cores are too short by noticeably more, maybe even as much as 1/4 inch. I've not seen one in-person. What you have should be correct. The raised portion on the bottom of the driven gear rides on a machined ledge inside the block at the bottom of the distributor hole, photo 1. This keeps the cam & distributor gears meshed correctly. When the driven gear is too high the pitch of the cam gear pulls down on the shaft and trashes the upper end of the shaft bushing inside the distributor, and/or grinds the fly-weight hardware into the bottom of the distributor housing. https://www.ctci.org/distributor-installation/ . Last edited by dmsfrr; 02-02-2021 at 10:23 AM. |
02-01-2021, 07:39 PM | #18 |
It would appear there is enough play to make up the difference.
02-02-2021, 09:30 AM | #19 |
Turning in enriches - Turning out leans
!!! INCORRECT INFORMATION !!! - Turning In Leans - Turning Out Enriches (Sal caught me again)
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 02-03-2021 at 09:09 AM. Reason: INCORRECT ENTRY |
02-02-2021, 11:20 AM | #20 |
Thread Tools | |
Display Modes | |
