Old 08-02-2020, 03:14 PM   #1
vangogh
Default shocks
Hi! I have had a senior mid life at 75 and got a '31 Vicky in primo condition. Need to know what type of oil to put in the shocks. Any type will do? Thanks!
vangogh is offline   Reply With Quote
Old 08-02-2020, 03:52 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: shocks
Hydraulic oil. It comes in different weights.
The Model A vendors also sell it.
Do not use Glycerine.
Old 08-02-2020, 04:59 PM   #3
vangogh
Red face Re: shocks
So what weight should I use and get at the neighborhood parts dealer?
thanks
Old 08-02-2020, 05:20 PM   #4
Mulletwagon
Mulletwagon's Avatar
Default Re: shocks
Had my senior mid life at 70 and got a 31 Tudor. Nothing like an old ride to help recapture your youth !! Good on ya.
Mulletwagon is offline   Reply With Quote
Old 08-02-2020, 05:30 PM   #5
Gary WA
Gary WA's Avatar
Default Re: shocks
20 wgt Hydraulic jack oil will work
www.whidbeymodelaclub.com
Old 08-02-2020, 07:05 PM   #6
vangogh
Default Re: shocks
thanks Gary
Old 08-03-2020, 09:15 AM   #7
Richard Lorenz
Default Re: shocks
In my experience, most older shocks need oil that is much thicker than 20 weight.
Richard Lorenz is offline   Reply With Quote
Old 08-03-2020, 04:55 PM   #8
Patrick L.
Patrick L.'s Avatar
Default Re: shocks
Yep.
If I remember correctly Stipe's come with 30.
Depending on the shock condition, I think I'd put in heavier.
Old 08-03-2020, 05:21 PM   #9
Lona
Lona's Avatar
Default Re: shocks
Congrats on getting your Vicky! If the car is new to you and needs fluid in the shocks, good chance the shocks are shot and will not hold oil. Suggest you try one at a time to make sure you don't leak oil all over your garage floor or driveway. Don't ask me how I know.
Glen
'31 Model A Deluxe Roadster
'31 Chrysler Model 70 Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 08-03-2020, 05:29 PM   #10
Kurt in NJ
Kurt in NJ's Avatar
Default Re: shocks
Multi viscosity tractor hydraulic oil
Motorcycle fork oil--- many weights to choose from
Auto transmission fluid can work if the shocks have no wear--- it's in my oil can, gets used for many things, what I am using in my shocks now, but my shocks are internally tight enough that closing the needle valve will stop movement
Some shocks will need gear oil, some nothing helps
Originally was glycerin based fluid
Old 08-03-2020, 05:42 PM   #11
warhorseracing
warhorseracing's Avatar
Default Re: shocks
I am currently rebuilding mine and have an ongoing technical post on the H.A.M.B. Some of the information I have uncovered says this.
And to help with adjusting.
warhorseracing is offline   Reply With Quote
