08-07-2018, 06:27 PM | #1 |
39 Merc All Terrain Vehicle???
Well, not really.
Ive got a stock 39 Mercury sedan that Ive been taking on camping trips this summer. Other than a few cooling issues that Ive mostly got solved, I notice that climbing hills is tough on the old Merc. Paved or not, it seems to hate pulling up a decent incline (especially from a dead stop!) I have a 59 GMC thats 100% stock that wil damn near idle up a cliff side in granny low. I realize they are very different machines, but Id kind of like it if the Merc was capable of something close to my GMC. So, the question is this: what period (40s era) upgrades can be done to the Merc to improve its hill climbing ability? The drivetrain is rock solid on the 39 and on highways and surface streets, I dont have a single complaint. Weird request, I know, but Im interested to hear what you guys come up with. |
08-07-2018, 10:36 PM | #2 |
Re: 39 Merc All Terrain Vehicle???
You can gear it lower but hiway driving would suck.Get a running start on those hills.
08-07-2018, 10:40 PM | #3 |
What kind of compression do you have on the merc?
What rearend do you have? 3.78? Higher ratio will increase engine rpm and heat btw |
08-07-2018, 10:51 PM | #4 |
A period correct solution would be the Columbia 2 speed rear axle.
08-08-2018, 02:35 AM | #5 | |
Also, im running 6.50x 16s. Im aware that a 6.00x 16 would help the situation slightly. Car will currently do between 60-65 on the freeway, so like I said, I really cant complain. Anyway, gonna slap a new Walker radiator in it next week and hit some hills. It could just be that I just need more experience with it. |
08-08-2018, 03:59 AM | #6 |
It is great that you are using your 1939 Mercury Town Sedan. I hope that you get the hill climbing issue sorted out? |
08-08-2018, 07:18 AM | #7 |
There were different first gear ratio transmission gear sets with lower first gear
08-08-2018, 08:05 AM | #8 |
29 x 15 lower gear set will help in pulling away. 29 tooth cluster gear ,15 tooth main drive gear...........versus 28 x 16. Lots of 29 x 15's around.
Charlie ny |
08-08-2018, 08:08 AM | #9 | |
this is probably your best answer... call up mac van pelt and see what he has. I think I have one of the lowest sets available at the time. it's from a commercial truck that had the 4 cylinder so it's the super low first gear. one other question is if you are at altitude during the hill climbing. you may be losing power that way?? Last edited by revkev6; 08-08-2018 at 08:36 AM. |
08-08-2018, 08:44 AM | #10 |
Marmon Herrington converted about any Ford vehicle requested to 4WD starting in 1936 or so. A conversion like that would be about as close as you would ever get to a 1959 GMC 4WD.
Those early Mercury cars had a different set up on ring & pinion than their Ford counterparts. The pinion was part of the drive shaft. This makes changing a ring & pinion set or even a complete rear axle a real chore. A new drive shaft set up has to be fabricated unless a person found an original set of 4.11 gears for a Merc. A lot of Mercs had the 15/29 transmission gears in the early years of the marque but I'm not sure about the 1939. |
08-08-2018, 09:29 AM | #11 |
Have the factory heads shaved for higher compression will help.
08-08-2018, 02:56 PM | #12 |
Before considering a gear swap in the trans, compare 2nd gear ratios. If you have to downshift to 2nd on a hiway grade, the lower ratio 1st gear also means a lower (slower) 2nd gear ratio, which may be too slow. What you need are more gears! A swap to a modern T-5 five speed would be ideal. It's a rather common swap; lots of info on this forum. A number of different gear ratios are available for this trans, too, from an extremely low first gear to an extreme overdrive and lots in between. Your car is already floor shift so that won't look much different. The period correct Columbia 2 speed rear axle will actually give you 6 speeds total,(a gear for every hill!).
08-08-2018, 03:06 PM | #13 |
Also consider milling the heads to get the proper "quench", or "squish" dimension (head to piston clearance) as well as more compression. This will pep the old girl up noticeably.
08-08-2018, 10:23 PM | #14 |
Just drive it.. very carefully.. and enjoy...
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
08-08-2018, 10:32 PM | #15 |
^^^ like this thinking right off if you want to just drive and enjoy how a 39 merc drives. Don't run it down.
Adding a little compression isn't going to hurt either. |
08-09-2018, 12:12 AM | #16 | |
..and for the "take it easy, don't kill it crowd..." I totally understand the sentiment that we should "drive carefully and enjoy.." these cars. There is certainly merit to that approach, but my brain rejects it as somehow demeaning to the engineering and strength designed into these vehicles. I've had restored cars that are too nice to park in parking lots. I've had old cars that I updated with new technology like disc brakes and small blocks and I've had old cars with tired running gear that I was afraid to take certain places for fear of something breaking. The point? I'm currently interested in old technology that performs at least as good as it did when new. These machines did great things in adverse situations back when they were new. There is no reason they can't accomplish the same tough tasks today. Besides, if a trip to the hardware store is fun in an old car, imagine how fun a trip to an abandoned silver mine 25 miles up a shitty road would be! |
08-09-2018, 07:13 AM | #17 |
Somehow, I'm reminded of the classic scene from "It's a Mad, Mad, Mad, Mad World" featuring Phil Silvers and a 1948 Ford Convertible. :-) See attached at 0:28 and again around 1:21. https://www.youtube.com/watch?v=HhaPZagxWpM
Regards, Scott '47 Mercury Convertible '25 Dodge Bros. Touring Car '63 MG Midget |
08-09-2018, 10:08 AM | #18 | |
[IMG][/IMG] |
08-09-2018, 10:58 AM | #19 |
From the historic information I've read on MH conversions, they liked to do the Fords better than the rest since they were easy to modify. They cut the axle bells on a standard Ford rear axle and installed their own constant velocity joint steering set up to make a front axle for 4WD conversions. They liked the 11-inch clutch and the T9 transmission too. It would be interesting to see what sort of transfer case they used on the light duty applications in the mid 30s and up to the war years. They made a lot of their own stuff for those conversions.
08-09-2018, 11:10 AM | #20 |
The light-duty M-H transfer cases were single-range, either engaged full-time - with no shift lever - (the CV joints free-wheeled on curves), or could be shifted from that funtion (called "COMPENSATING") to locked into "POSITIVE DRIVE" (no freewheeling) for loose traction situations. In either case, the hubs stayed engaged.
