Old 11-11-2015, 09:38 AM   #1
TinCup
TinCup's Avatar
Default Shorting Plugs has no effect
Recently put a new head on a car that had been setting for over 8 years due to a cracked head. I went through the valves and have installed known good plugs, distributor, carb, coil all the things that make this car go. I have set the timing so many times I have visions of the rotor at 4:00 in my head. Verified timing mark and TDC.
Car runs lousy. Stumbles as if it was missing but only number 4 plug can short to the block and cause it to stumble. I have good spark at all 4 plugs.
Throw this dog a bone I am tired of chewing on this.
TinCup is offline   Reply With Quote
Old 11-11-2015, 09:45 AM   #2
George Miller
George Miller's Avatar
Default Re: Shorting Plugs has no effect
Do you have compression on all 4 cylinders. If so how much?
You say you went through the valves. Does that mean grinding them?
George Miller is offline   Reply With Quote
Old 11-11-2015, 10:02 AM   #3
TinCup
TinCup's Avatar
Sorry forgot to mention 60-65 all cylinders. Gapped all valves.
Old 11-11-2015, 10:05 AM   #4
George Miller
I would check for a vacuum leak at the intake. You also could have a sticking intake valve.
Old 11-11-2015, 10:44 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Kinda' weird, TinCup,
Compression tests indicate that valves are OK.
Are you using manifold gland rings? "Maybe" 1 is cocked or too thick to let the manifolds seat against the block well??
Spray a little Chem-Tool or Propane around the manifold gasket & see if it RUNS BETTER. "Maybe" a rag or paper wadding got left in intake manifold??? Or "maybe" the exhaust might be plugged???
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 11-11-2015, 10:49 AM   #6
1955cj5
1955cj5's Avatar
You might try a different (new) set of plugs, or swap the ones you have around and then see which cylinder stumbles...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 11-11-2015, 11:07 AM   #7
George Miller
The reason I said it could be a sticking valve is because you had a leaking head and then it set for many years.
I have seen sticking intakes on many Model A's that had been sitting over the years. They could have compression when turning slow with the starter, but slow to close when running. If it is not the intake manifold leaking you might try mystery oil in the gas, or through the carb intake.
Old 11-11-2015, 11:08 AM   #8
5lugnuts
Change the condenser!
5lugnuts is offline   Reply With Quote
Old 11-11-2015, 01:57 PM   #9
heneste
heneste's Avatar
Is it possible the number 4 spark plug is cracked anywhere? You would still get spark but it may be shorting out under load.
heneste is offline   Reply With Quote
Old 11-11-2015, 02:17 PM   #10
Dollar Bill
Dollar Bill's Avatar
I had the same symptoms you describe. Resolution was vacuum leaking between intake and block due to a faulty gasket.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 11-11-2015, 02:19 PM   #11
johnbuckley
johnbuckley's Avatar
Surely as I read #1 , it's cyl number 4 that's doing most of the work!? Or is something missing on this transatlantic transmission?
Is idling and powering under load equally bad, Tin Cup?
johnbuckley is offline   Reply With Quote
Old 11-11-2015, 02:23 PM   #12
johnbuckley
test for this by spraying Eezy Start at the gaskets there- careful it's explosive!
Old 11-11-2015, 02:54 PM   #13
MikeK
MikeK's Avatar
The dizzy body may have an internal arc-over short. Try a different one.
MikeK is offline   Reply With Quote
Old 11-11-2015, 03:55 PM   #14
pooch
pooch's Avatar
Try running it with the brass plug strips off and about 1/4 inch away from dizzy cap, forcing the spark to jump to each strip, and then short out each plug.
pooch is offline   Reply With Quote
Old 11-11-2015, 04:10 PM   #15
daveymc29
daveymc29's Avatar
I had a valve slow to close. Put Marvels Mystery oil in the cylinder and cranked it over with the key of, put a tad more in the spark hole, put the plug in, cranked again a few revs with the key off, let it sit over night and have driven faithfully for the last several months. I do put about 2 to 4 oz of MMO in the gas tank on each fill up if I remember to do it. Helps with the carb float valve sticking also. Our gas-o-crap is awfully dry, doesn't lube anything passing through.
daveymc29 is offline   Reply With Quote
Old 11-11-2015, 04:27 PM   #16
meteorgray
Had the same issue with my 40 buick. Seemed like a fuel problem. I,m with 5lugnuts it was the condenser.
meteorgray is online now   Reply With Quote
Old 11-11-2015, 06:45 PM   #17
TinCup
TinCup's Avatar
Change plugs today with no improvement. Also reinstalled the original distributor with another diz body that I rebuilt and there is no change in the behavior. The lopping is more pronounced at low rev that higher rpm's. Added some MMO to the gas and oil today and ran it for a good 30 minutes. Going to let it set overnight and see if it has any effect on the valves.
I replaced the exhaust and intake gaskets but I am going to pull it tomorrow and replace them along with another intake and exhaust and see if that is the culprit.
I have a little water coming out the *8 stud but it's just a drop or two. Other than that the head was torqued to 55.
If I hook up the vacuum gauge what should I be looking for.
Old 11-11-2015, 08:01 PM   #18
Tom Wesenberg
Tom Wesenberg's Avatar
Look for a bouncing needle if you have a sticking valve.
Old 11-11-2015, 08:38 PM   #19
1955cj5
1955cj5's Avatar
I agree with John from across the pond........If the car stumbles badly when shorting #4, I would say #4 is doing it's job correctly, but when taken out of the picture the stumble is more noticeable.
If you short the stumbling cylinder the stumble should go away... the engine will run poorly, but smoothly...
Old 11-11-2015, 09:06 PM   #20
jm29henry
jm29henry's Avatar
Check the la,laminated timing gear ?
jm29henry is offline   Reply With Quote
Old 11-12-2015, 05:14 PM   #21
TinCup
TinCup's Avatar
Replaced the intake and exhaust manifolds with a spare and the car now runs. One of the middle exhaust had a cracked ear and was blowing directly on the intake port. Vacuum gauge showed the manifold leak. All is back together and even took it down the street for a drive but it is a tired motor. More noise from the valve chamber than I would like and according to the vacuum gauge either sticking or worn valves. Placed my gauge on a newer Ron Kelly motor this morning for comparison and it showed what it should be not what I have. Between the shorted coil and the manifolds this has been anything but usual. Thanks for all the input. I am now a firm believer in the use of the vacuum gauge.
Old 11-13-2015, 12:59 AM   #22
Mike V. Florida
Mike V. Florida's Avatar
for those that have little knowledge of the gauge;
http://www.secondchancegarage.com/public/186.cfm
Old 11-13-2015, 01:58 AM   #23
BILL WILLIAMSON
And if you SLOWLY rev it up to about 2,000 RPM & the gauge SLOWLY goes to "0"--the exhaust is PLUGGED UP.
Bill W.
