11-10-2015, 07:23 PM | #1 |
New Coil Woes
New 6V Napa coil shorts to ground in the firewall mount. Outside of the mount coil works fine put it in the strap and no fire. Insulate the mount with black tape and it works.
Oklahoma City Model A Restorers Group. |
11-10-2015, 07:29 PM | #2 |
Re: New Coil Woes
Take it back for replacement. New things do fail.
11-10-2015, 07:41 PM | #3 |
Re: New Coil Woes
I also had a bad NAPA coil, only mine was 12 volt.
JB |
11-10-2015, 09:51 PM | #4 |
Re: New Coil Woes
yea coil is grounded to case which shouldn't be... take it back and get a new one.
1929 Model AA - Need long splash aprons! |
11-10-2015, 09:55 PM | #5 |
Re: New Coil Woes
" take it back and get a new one." somewhere else
______________ Nothing Short of Right is Right |
11-11-2015, 05:02 AM | #6 |
Re: New Coil Woes
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
11-11-2015, 02:19 PM | #7 |
Re: New Coil Woes
Both sites were great Keven, thanks. I once replaced my spark plugs(modern car) due to a miss traced to plugs, but it did not solve the problem. Changed wires, gaskets and sundry other items. Well I finally found the trouble and it was a plug, an old one and then 1 new one I replaced it with. New does not = working all the time.
11-12-2015, 02:21 AM | #8 |
Re: New Coil Woes
Thanks, bit of a hobby!
Just goes to show, glad you got to the bottom of things
11-12-2015, 09:24 AM | #9 |
Re: New Coil Woes
I have since talked to several guys locally that have run into the same problem. Taking it back today and I am taking my meter to make sure the replacement isn't grounded.
