Old 02-25-2021, 12:05 PM   #41
tubman
tubman's Avatar
Default Re: Trouble shoot 1950 8Ba initial start up Help
If it has never been run since the rings were installed, the rings have probably not seated and those numbers may not be as bad as they seem. They should be sufficient to start the engine though.
Old 02-25-2021, 12:18 PM   #42
JSeery
JSeery's Avatar
The compression numbers don't look that bad for unseated rings, so that should rule out any valve issues. So about has to be an ignition problem. Can you post a couple of photos of the distributor in place that shows the wiring harness and how it is routed to the plugs?
Old 02-25-2021, 12:19 PM   #43
flatjack9
flatjack9's Avatar
Those numbers are more typical of a worn engine. As noted there is enough compression to start it. Problem would seem to be improper timing.
Old 02-25-2021, 12:19 PM   #44
JSeery
JSeery's Avatar
Also, when you check the spark at the plug, is it a bright blue spark?
Old 02-25-2021, 12:26 PM   #45
tubman
tubman's Avatar
If you are serious in trying to get this started, I suggest removing the dual carb thingy, bolting your best carburetor directly to the manifold and replacing the spark plugs with new ones (the existing plugs are probably very compromised from the previous attempts at priming the engine in various ways). Make sure you still have spark and gas to the carb. Give it one more try before tearing it down.
If it still doesn't start, you might try turning the distributor 180 degrees and resetting the timing.
Old 02-25-2021, 01:21 PM   #46
40cpe
40cpe's Avatar
My thoughts? It should fire on your compression. The oil increases compression because the rings aren't seated.
Old 02-25-2021, 01:44 PM   #47
backrodebob
backrodebob's Avatar
If that’s the case, wad a piece of paper towel stuff in plug hole bump engine when it pops out your on compression stroke
backrodebob is offline   Reply With Quote
Old 02-25-2021, 07:37 PM   #48
Ronnie
Ronnie's Avatar
Is yours like this? If so the cam is in correct R
Ronnie is offline   Reply With Quote
Old 02-25-2021, 11:09 PM   #49
dono50
dono50's Avatar
Send a message via MSN to dono50
If you’re using repro condenser and points they are junk. I had problems on initial start up because of weak spark. Bought NORS condenser and point and it started right up.
dono50 is offline   Reply With Quote
Old 02-26-2021, 06:35 AM   #50
Bustingear
Appreciate all the help! Spark is BLUE
New 12V harness installed for complete car
Power Master starter and Power Master generator
Which is an really an Alternator
These are the best $600 with tax between the two
12 volt system and new battery that I charge between intervals
Starter is strong and fast
I am going to convert to adjustable lifters and a new intake
Between the two I think I will have exhausted the issues
Yesterday Sprayed ether and poured fuel down the hatch again today and still the plugs did not smell strong of gas or ether as they should nor did they appear wet . I think that hokey carb set up is bogus and maybe my 94 rebuilds suck although they are squirting???
It’s almost like there is a blockage which is why I am going after the induction set up
Bustingear is offline   Reply With Quote
Old 02-26-2021, 07:52 AM   #51
jimvette59
jimvette59's Avatar
I think the cam gear dot is three teeth to the left.
jimvette59 is offline   Reply With Quote
Old 02-26-2021, 08:26 AM   #52
51 MERC-CT
51 MERC-CT's Avatar
Just a suggestion, before I did anything else, I would remove the phony dual intake (as previously suggested).
Mount a single carb and try it that way.
Old 02-26-2021, 09:34 AM   #53
Bustingear
If you look back at the thread you will see crank dot and cam slash line up while pulley dot and pointer line up and rotor is setting at number one plug wire. We have established that.
Old 02-26-2021, 09:35 AM   #54
Bustingear
51merc and Tubman good test suggestion on single carb and will try before getting rid of more eagles$$$$$
Old 02-26-2021, 09:40 AM   #55
Bustingear
question regarding distributor vacuum advance. currently one of the 94 carbs has the vacuum port built in. If i switch to a different 94 without can i run the vacuum advance line to an aluminum spacer between the 94 and the manifold? Will it work there?
Old 02-26-2021, 09:57 AM   #56
19Fordy
19Fordy's Avatar
Is the distributer gear on the cam correctly installed and is it tight
so as not to rotate when it meshes with the distributor gear?
Old 02-26-2021, 10:05 AM   #57
51 MERC-CT
51 MERC-CT's Avatar
No, the stock distributor requires ported carb. vacuum to operate correctly, not manifold vacuum.
Old 02-26-2021, 10:05 AM   #58
JSeery
JSeery's Avatar
No, that distributor requires a specific carburetor to work. It needs a mixed signal from both above and below the throttle plate.
Old 02-26-2021, 10:58 AM   #59
Ken Henry
Ken Henry's Avatar
It should do something with starting fluid and the compression readings you are getting. I'm unsure if adjustable lifters will accomplish anything at this point. Do you have another stock distributor that you can swap in? Maybe the Petronix is flaking out...
Ken Henry is offline   Reply With Quote
Old 02-26-2021, 11:50 AM   #60
Bustingear
checked it at the spark plug tip while in rotation
