Old 05-01-2021, 01:20 PM   #1
40larry
Default Ron Francis
Can someone provide me with contact info to reach Ron Francis regarding his constant voltage reducer. Thanks..........40larry
40larry is offline   Reply With Quote
Old 05-01-2021, 01:43 PM   #2
woodiewagon46
Default Re: Ron Francis
Ron Francis Wiring, 800-292-1940, www.RonFrancis.com.
woodiewagon46 is offline   Reply With Quote
Old 05-01-2021, 01:44 PM   #3
Bob C
https://www.ronfrancis.com/
Old 05-01-2021, 07:04 PM   #4
russcc
They are in PA, but as heads up, I checked with them on CVRs and they were way expensive, plus the shipping was also up there. There are other sources that seem more reasonable.
russcc is offline   Reply With Quote
Old 05-02-2021, 01:19 PM   #5
40larry
Could you suggest any other source???? Thanks......Larry
Old 05-02-2021, 01:25 PM   #6
Angledrive
Angledrive's Avatar
What are you trying to power or reduce the voltage to?
Angledrive is offline   Reply With Quote
Old 05-02-2021, 06:35 PM   #7
russcc
There was a post by 19Fordy on the barn about how he converted his '40 gauges using and inexpensive CVR. I fi can find it, I will post it. Good ? by Angledrive.
Old 05-02-2021, 07:15 PM   #8
paul2748
paul2748's Avatar
Is the Ford Instrument Voltage regulator the one you are looking for? They were used in 57 and up Fords (don't know when they stopped (80's sometime). These should be available in a parts store. Dennis Carpenter has them. One for a 65 Mustang is 21.95 . There was a couple of different designs over the years, but as far as I know preformed the same function. 10804 is the group number
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-02-2021, 07:46 PM   #9
Angledrive
Angledrive's Avatar
I use an electronic unit I purchase from NPD for gauges. Part number 10804-1E, 39.95.
Old 05-03-2021, 08:23 AM   #10
TJ
TJ's Avatar
I believe that Napa Auto Parts also carries them.
Old 05-03-2021, 11:20 AM   #11
40larry
three six volt 1940 Ford gauges
Old 05-03-2021, 01:31 PM   #12
jetmek
If i recall VR-1 from napa
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 05-03-2021, 09:29 PM   #13
jayvee34
jayvee34's Avatar
Speedway motors carry a 12 to 6 volt 1 amp reducer called a "runtz"
I have used them before and they work real well. (one for each gauge)
they cost about 20 bucks each.
They also carry another reducer that will handle 3 gauges.
P.S. It can also correct a Amp gauge if you are running one.
jayvee34 is offline   Reply With Quote
Old 05-04-2021, 05:40 PM   #14
russcc
Found my notes, Ron Francis wanted $61.95 plus $15. shipping for a CVR-1. "19Fordy on this site did a great "how to" on 2/5/2014 in response to a post by Roger W Gerow entitled "converting instrument voltage". That's the blueprint I am using.
Old 05-05-2021, 03:02 PM   #15
40larry
Does anyone know why the Runtz devices must be used one to a gauge. The Runtz devices are rated at 4 amps each and the Ford King Seeley gauges use about 1/10 amp each.
Old 05-05-2021, 03:14 PM   #16
russcc
Most of the conversions use the CVR-1 like 19Fordy did, vs the Runtz because you have to get one for ea gauge.
Old 05-05-2021, 03:36 PM   #17
Robz51
Robz51's Avatar
I used this on my 51 and it repeatedly everheated and shut off. It would later work but shut off again. Not sure where you could mount it to prevent this. I use the runtz now and they work well.
Sent from my SM-G955U1 using Tapatalk
Robz51 is offline   Reply With Quote
