Old 05-01-2021, 12:10 PM   #1
ahshoe
Default 8” Ford ring and pinion ratios
Looking for the different rear ratio available for a Ford 8” ring and pinion
ahshoe is offline   Reply With Quote
Old 05-01-2021, 12:15 PM   #2
55blacktie
Default Re: 8” Ford ring and pinion ratios
If you want to know what new parts are currently available, just go to Summit Racing and search Ford 8" ring and pinion gears. My wife's cousin's husband has 3.50 gears in his 64 1/2 Mustang Convertible/w C4 transmission. There are times when he wishes he had retained the OEM gears for the highway, probably 3.00.
55blacktie is offline   Reply With Quote
Old 05-01-2021, 12:21 PM   #3
55blacktie
mustangattitude.com/mustang/1965dtrearend.shtml
Old 05-01-2021, 04:53 PM   #4
Sid
Sid's Avatar
I know for sure factory 2.79---3.00----3.25----3.40---3.55. and probably 4.11. I'm sure there is something else in between 3.55 and 4.11.
Sid is offline   Reply With Quote
Old 05-01-2021, 06:47 PM   #5
55blacktie
Keep in mind that the mustangattitude list may include ratios for the 7 1/4" rear axle used on 6-cylinder car, the 9" used on K-code HP 289, as well as those for the 8". I think the 3.00 is the most common for the 8".
Old 05-02-2021, 07:40 AM   #6
Ford Freak
I have 2:75's in my stock Falcon Sprint . Like them a lot on the highway, & decent takeoff acceleration .
1952 Ford F1
1965 Ford Falcon Sprint
2007 Ford Mustang GT
Ford Freak is offline   Reply With Quote
Old 05-07-2021, 10:12 AM   #7
Mossback
I have a Maverick 8" with 3.80 ratio aftermarket gears in my '32 Desoto. It's perfect with my overdrive transmission -- 2100 rpm at 70 mph.
Mossback is offline   Reply With Quote
Old 05-07-2021, 11:08 AM   #8
55blacktie
An 8" in good condition can handle up to 300 hp with no problem. There are no carrier breaks, so you can use any available ring and pinion gear ratios without changing carriers.
Old 05-15-2021, 05:37 PM   #9
Jwawhite
Jwawhite's Avatar
It seems in my Wagon the gearing may be too low in OD.
How can I ascertain the gearing in mine w/o removing the driveshaft and pumpkin?
Jwawhite is offline   Reply With Quote
Old 05-15-2021, 06:51 PM   #10
KULTULZ
KULTULZ's Avatar
Post Re: 8” Ford ring and pinion ratios
https://shiftsst.com/blog/post/how-t...xle-ratio.html
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 05-16-2021, 12:19 AM   #11
miker98038
miker98038's Avatar
jwawhite, if it’s the original, it should be a Dana, probably a 44. The V8 o/d cars were either 3.7x, 3.9x, or 4:11’s IIRC. The 6 cylinder o/d were 4.27 or so. So you have to watch close turning and counting. Not a lot of spread. I’ve always thought the 3.9x or 4:11’s were good in o/d on the freeway. I had a 4:27 out of a wagon in a 312 bird. It was great when I was 18.
miker98038 is offline   Reply With Quote
Old 05-16-2021, 04:58 PM   #12
ahshoe
Looking for 8" 28 spline, open or trac loc 3.25
