Old 04-14-2021, 12:06 AM   #1
coxswain98
Default Original color
Is there any way to know what color the car was originally painted? 1939 coupe
coxswain98 is offline   Reply With Quote
Old 04-14-2021, 02:16 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Original color
Look for traces on the sheet metal somewhere.Ford vin numbers of that period did not have color codes in them,TMK.
deuce lover is online now   Reply With Quote
Old 04-14-2021, 07:10 AM   #3
Kube
Kube's Avatar
Deuce is correct of course - there is no way to know for certain what color the vehicle was when it left the assembly line.
Often enough, there are traces of the authentic color inside the door.
Old 04-14-2021, 08:33 AM   #4
Zax40
Zax40's Avatar
I've noticed flat black paint under some of the trim pieces on my '40 which is Cloud Mist Grey and was repainted at some point the distant past. Does that mean it may have been black originally? Or were there some black primers used at one time in the past?
Zax40 is offline   Reply With Quote
Old 04-14-2021, 09:19 AM   #5
TJ
TJ's Avatar
Black primer was common. Look behind your kick panels as you will usually see traces of the original paint. Also check the trunk area (braces, etc.)
TJ is online now   Reply With Quote
Old 04-14-2021, 12:16 PM   #6
DavidG
DavidG's Avatar
Also underneath the cowl.
DavidG is online now   Reply With Quote
Old 04-14-2021, 07:29 PM   #7
Kube
Kube's Avatar
Good point and one I should've remembered. I have used this area to match shades for past restorations. Like inside the doors, it is out of the light and weather.
Thanks for slapping my memory bank Dave.
Old 04-14-2021, 09:47 PM   #8
DavidG
DavidG's Avatar
Mike,
You're welcome, as always.
Old 04-14-2021, 11:06 PM   #9
slowforty
slowforty's Avatar
Also under the package tray
slowforty is offline   Reply With Quote
Old 04-14-2021, 11:37 PM   #10
swoopNZ
MEMBER EMERITUS
Also the trunk handle base area.
swoopNZ is offline   Reply With Quote
Old 04-14-2021, 11:56 PM   #11
Lanny
Lanny's Avatar
The original trunk lid could have been replaced, I would
look at panels inside the trunk area or interior of car.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
