Old 04-09-2021, 12:52 PM   #61
hazelhoff
hazelhoff's Avatar
Default Re: Engine not starting - checked everything - no more idea
I had the same thing after rebuilding the engine. Everything was OK, but it did not run !
Finally checked the camshaft timing. That was completely wrong, 10% off !
Do check the timing, cam gear dot to the right edge of the crank gear peg.
Wish you luck !
Henk
You don’t own a Model A ... it owns you !
hazelhoff is offline   Reply With Quote
Old 04-11-2021, 06:36 AM   #62
Ray64
Ray64's Avatar
Did you paint the engine and leave tape over the intake and exhaust holes? I did that
Ray64 is offline   Reply With Quote
Old 04-11-2021, 06:36 AM   #63
Michael_Velling
The car runs fine, tried it for a ride about 25 km - last week. This weekend heavy rain here near the dutch border.
@Henk / Hazelhoff: Did you send the rain?
Michael
Greetings
Michael
Toenisvorst, Germany
Michael_Velling is offline   Reply With Quote
Old 04-11-2021, 08:22 AM   #64
McMimmcs
McMimmcs's Avatar
Originally Posted by Michael_Velling View Post
Okay, but mechanical must the fuel go into the combusion chamber and there is no fuel. The electrical problem may come then when fuel is in the cylinders.
Michael Velling
Germany
www.velling.de
Did you not recently have it running ?
McMimmcs is offline   Reply With Quote
Old 04-11-2021, 11:29 AM   #65
tuneman
tuneman's Avatar
I would suspect the gav needle is broke off at the tip ,with a new needle inserted into it. thus working as though the valve was turned all the way in. there beirng no adjustment.
tuneman is offline   Reply With Quote
Old 04-12-2021, 05:42 PM   #66
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I don’t understand why everyone keeps trying to solved a now nonexistent problem!?
Old 04-12-2021, 07:46 PM   #67
McMimmcs
McMimmcs's Avatar
That was why I asked two posts back if he had it running.
Old 04-13-2021, 12:39 PM   #68
hazelhoff
hazelhoff's Avatar
Michael
Of course Michael. There is a lot of good stuff coming from Holland
Grusse,
Henk
