12-07-2018, 12:17 PM | #1 |
engine identification
I bought this 21 bolt, water pump in block(covered) Heads are numbered as for domed pistons Block has the pictured markings. There is a sticker on the head from a ford approved rebuilder. What year is this block ?
12-07-2018, 12:20 PM | #2 |
Re: engine identification
Think it would be very difficult to tell with the information you have posted. Keep in mind that external parts are easily swapped around.
12-07-2018, 12:26 PM | #3 |
21 stud pump in block is 37 and most 38 ford
12-07-2018, 02:50 PM | #4 |
I was hoping the block could be furthur identified by the photo of the block stampings I posted but expect that recast blocks had many different than original Ford stamps. It should have domed pistons but will have to remove the heads to be sure.
12-08-2018, 12:53 AM | #5 |
21 stud pump in block engines were exclusive to '37 & '38 cars and trucks, but continued to be produced for service replacement and stationary industrial engines. I have no idea how long they continued to be made.
Alan |
12-09-2018, 10:58 AM | #6 |
