Old 06-18-2018, 01:41 AM   #1
Anteek29
Anteek29's Avatar
Default Room in P-U Cab?
I have not yet tried to sit behind the wheel in a closed pickup. Would there be much difference from what I have in my stock '29 coupe?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 06-18-2018, 07:00 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Room in P-U Cab?
Yes, I find pickups to be the tightest fit, and the least comfortable.
Old 06-18-2018, 07:49 AM   #3
john in illinois
john in illinois's Avatar
+1^
John
john in illinois is offline   Reply With Quote
Old 06-18-2018, 07:53 AM   #4
jhowes
My brother picked up between 1 and 2 inches of room in his pickup by redoing the seat back. Can you imagine driving and making deliveries all day every day in such a tight and cramped space. The AA cabs were the same as the PU.
jhowes is offline   Reply With Quote
Old 06-18-2018, 08:49 AM   #5
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
6' 200lbs here. I had to modify the shift lever just so I could get my foot from the accelerator to the brake quickly when in low gear because it is so cramped. If I could do it all over I would not have a closed cab pickup.
MickeyT is offline   Reply With Quote
Old 06-18-2018, 09:25 AM   #6
Anteek29
Anteek29's Avatar
Thanks guys...based on your responses so far I just might have to dismiss having a p-u...I am 6', 195 lbs. My coupe is a bit cramped as it is.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 06-18-2018, 09:41 AM   #7
CHuDWah
CHuDWah's Avatar
I'm about your size and I've had both coupe and closed cab. Both were 30-31 which I think are a bit roomier than 28-29. I could drive the truck but it would have been a problem if it was much smaller. In any case, I wouldn't have wanted to drive very long in it. The coupe had adjustable seat (don't think 28-29 does) - with the seat all the way back, it was OK.
CHuDWah is offline   Reply With Quote
Old 06-18-2018, 09:56 AM   #8
Art Newland
Art Newland's Avatar
I really wanted a pickup, I'm 6'2 250 and am pretty comfortable in my 30 coupe. I had a chance to try on a 29 and a 30 CCPU at a local Model A get together, the 30 was doable but no where as roomy as my coupe, the 29 was impossible to get all the way in and get behind the wheel. I settled on a 49 F1, still not lots of extra leg room.
"whatever works!"
Art Newland is offline   Reply With Quote
Old 06-18-2018, 10:32 AM   #9
SSsssteamer
SSsssteamer's Avatar
Standing at 6' 3" and all the while, I am getting more stove up, our CCPU was getting harder to comfortably drive. Trying to function in our '31 CCPU was becoming a challenge. Mods were made. 3" of seat springs were removed from the back rest for more body room. Also, 3" of seat springs were removed from the seat bench so that I could see under the windshield visor. The shifter was bent a bit to the right so that I could more easily lift my right foot to the brake pedal. The clutch pedal's limiting top stop was relocated so that the clutch pedal now doesn't raise as high out of the floor. The clutch pedal is now located two inches lower making it easier for me to lift my left foot to the clutch pedal. The '31 CC pick up now is more comfortable to drive than our 1930 Model A phaeton. To fix our phaeton next, I guess the same modifications will have to be made. For me, changing the seat springs' height for both of the seat cushions was the greatest improvement.
SSsssteamer is offline   Reply With Quote
Old 06-18-2018, 11:18 AM   #10
Jim Brierley
At least one of the aftermarket upholstery suppliers offers pickup seats that are thinner than stock. I'm also 6',1", 185 lbs. but quite flexible and have had no comfort problems in my wide-bed. Good luck!
Jim Brierley is offline   Reply With Quote
Old 06-18-2018, 11:30 AM   #11
Russ/40
Russ/40's Avatar
My 29 RPU is tight getting in and out, but I find it quite comfortable driving. Im 5'11" 185. Now if we are talking about a long tour, i might feel different. I had good advice as to how much padding to use in the seat, so I had as much room as possible.
Russ/40 is offline   Reply With Quote
