Old 05-29-2017, 04:17 PM   #1
keith oh
keith oh's Avatar
Default In reference to a previous thread regarding X8 Engine
eli apolzon <[email protected]>
In 2006, this man was selling an X8 engine to help with the hospital expenses of his daughter.
These pictures are of an actual X8 engine not just an engine designated with an X number.
keith oh is offline   Reply With Quote
Old 05-29-2017, 04:48 PM   #2
Capt Kirk
Capt Kirk's Avatar
Default Re: In reference to a previous thread regarding X8 Engine
A compressor pump??
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 05-29-2017, 06:12 PM   #3
keith oh
keith oh's Avatar
No, An 8 cylinder engine Ford designed at the same time he designed the V/8. I expect he was trying to compete with other in line 6 and 8 cylinder engines yet keep it shorter and as or more powerful.
Old 05-29-2017, 06:25 PM   #4
Ross F-1
Ross F-1's Avatar
Interesting! Note the cylinders are integral to the crankcase halves, not bolted to it like an airplane radial.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 05-29-2017, 06:43 PM   #5
koates
There was a Ford X8 engine on display in Henry Fords Fairlane home when I visited there in 2003. It was in the basement. Exactly the same as in those pictures. Henry tested several out fitted to model A cars and I think the bottom cylinders overheated because of accumulated dirt getting on the lower cylinders and restricting air flow. Regards, Kevin.
koates is offline   Reply With Quote
Old 05-29-2017, 07:25 PM   #6
tubman
tubman's Avatar
Anybody now if these were rotary engines? The gear-like indentation on the second picture sure looks like a drive element!
Old 05-29-2017, 08:45 PM   #7
koates
Rotary engines were used in WW1 aircraft and comprised of cylinders and crankcase which rotated around a stationary crankshaft. Radial engines were the opposite where the crankshaft rotated and the cylinders and crankcase remained stationary. The Ford X8 is like a radial engine, cylinders and crankcase stationary and the two flywheel come cooling fans rotated. The internal gear drive in the centre of one flywheel drove the transmission. Regards, Kevin.
Old 05-30-2017, 10:11 AM   #8
corvette8n
corvette8n's Avatar
Just think, if Henry succeeded with that motor and produced 12 million of them, we'd have an x8 forum instead
corvette8n is online now   Reply With Quote
Old 05-30-2017, 10:32 AM   #9
redmodelt
redmodelt's Avatar
The "X" engine is from 1920;
http://vintagefordfacts.blogspot.com...-8-engine.html
google "mtfca.com X engine"
If you want to know more.
Old 05-30-2017, 02:56 PM   #10
Jason in TX
Jason in TX's Avatar
Outstanding.
(I hope the original seller's daughter is now ok.)
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Thread Tools
Display Modes
