Old 05-28-2017, 07:09 PM   #1
Ian in Mississauga
Default e-brake retracting spring
I've installed these springs before but now I'm trying to do it with only vision in one eye and so far success eludes me. A friend who has done a lot of brake work on model As like swedging and arcing new shoes advises
doing it on the bench. My question is will the whole assembly with both actuating arms attached still fit through the gap in the radius rod? Any other advice?
TIA Ian
Ian in Mississauga is offline   Reply With Quote
Old 05-28-2017, 07:16 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: e-brake retracting spring
TIA Ian
I drop the rear radius rods. It is too difficult for me to pull that spring around anymore. If you had the e-brake carrier out to work on the service brakes you only have one more bolt to remove to drop the rear radius rods. Good Luck
Old 05-28-2017, 09:30 PM   #3
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I use a small steel cable like picture hanging cable and pull the end of the spring into place. Works pretty good.
Jacksonlll is offline   Reply With Quote
Old 05-28-2017, 10:32 PM   #4
kd4lok
kd4lok's Avatar
The spring remains uninstalled on one wheel of my car for some time now. I need to attack it again.
Bob
kd4lok is offline   Reply With Quote
Old 05-29-2017, 10:08 AM   #5
JBill
I've always found it easier to pull the spring around with a piece of wire rather than cord, which stretches too much.
JBill is offline   Reply With Quote
Old 05-29-2017, 11:44 AM   #6
Chris H
Chris H's Avatar
Out of desperation I fabricated a puller from a coat hanger and a piece of dowel rod acting as a tee handle. Pretty crude, but it worked well. Just enough flexibility, yet stiff enough to do the job. After all, it only had to work twice!
Chris H.
1930 Tudor
1964 MGB
1979 MGB
Ham call: N9WHH
Chris H is offline   Reply With Quote
