Old 06-30-2014, 12:13 PM   #1
Idaho Brett
Idaho Brett's Avatar
Default Confused and Concerned about Rear Main Leak
Finally got my Model A Running and Street Legal. But it leaks a lot of oil from the Cotter Pin below the Flywheel Housing when I drive it on the road. It does not leak when just idleing in the garage.
I dropped the Oil Pan to take a look at the Drain Tube that several people have talked about on other posts. I bought a drain tube from Snyder's hoping mine was missing, but there it was.
I compared the two tubes and my new one is about half an inch longer than the one I took off. (See Picture at end of Post)
TWO Questions:
1. Could the shorter tube cause the leak?
2. Is there any thing else I should look for while the Oil Pan is off before resigning to the fact I have bigger problems?
Thanks.
Idaho Brett is offline   Reply With Quote
Old 06-30-2014, 12:36 PM   #2
Russell in Tulsa
Default Re: Confused and Concerned about Rear Main Leak
Lay the old one on top of the new one and see if it is only 1/2" shorter. Looks like more to me. And yes a short one can be a problem.
Russell in Tulsa is offline   Reply With Quote
Old 06-30-2014, 12:45 PM   #3
1930artdeco
1930artdeco's Avatar
Have you noticed the threads are different.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-30-2014, 01:10 PM   #4
George Miller
George Miller's Avatar
Mike
I noticed that also.
Rear main leaks are cause by a lot of things. Number one to much crankshaft end play. To much clearance in the rear main bearing. Main cap not flat. Leaking around rear main bolts. Shims not in place. Leaking around rear slinger seal. To much crank case pressure. Drain tube plugged. Drain tube blocking drain hole. Babbitt in inside drain in rear main cap. Plus some I forgot. Also a lot of time you find it is the camshaft rear bearing that is leaking. If you do not want a leaker you have to check all this before you put it to together.
George Miller is offline   Reply With Quote
Old 06-30-2014, 01:53 PM   #5
pat in Santa Cruz
pat in Santa Cruz's Avatar
here is a good treatise on this problem linked below. Bottom line: its not always what you think it is. Check everything.
As long as the pan is off, check your main bearing clearances If the ctr main is loose, the flexing crankshaft acts like a pump, pumping the oil out the back. So check it too, even if it is a pain in the rear.
A very common cause is that the tube is screwed in to the cap so far it dams up the oil flow. Measure the # of threads into the cap and compare to the cap, then cut a "V" in the back side of the tube, leaving enough threads to catch the main cap, but none to occlude the channel so the oil has a way down and out the main channel. Be sure to tack the tube with a small MIG or TIG weld to secure it. Don't heat up the babbit so much it melts.
http://www.antiqueenginerebuilding.c...RMAINLEAK.html
pat in Santa Cruz is offline   Reply With Quote
Old 06-30-2014, 05:25 PM   #6
glenn in camino
glenn in camino's Avatar
Snyders sells a thing called a rear main janitor. It bolts to the bell housing and catches the oil drips from the rear main. I got one for my full pressure B engine that tens to leak a little because of the oil pressure. Works great.
glenn in camino is offline   Reply With Quote
Old 07-01-2014, 07:36 AM   #7
clo2jim
clo2jim's Avatar
The rear main janitor works well, but you have to remember to empty it periodically. Since oil does not evaporate, the rear main janitor will gradually fill up. Then when you go around a corner, the oil will spill out and put a nice oil line down on the road for a short distance
clo2jim is offline   Reply With Quote
Old 07-01-2014, 07:48 AM   #8
V4F
V4F's Avatar
have you checked to see if it is actually the rear main , or maybe the cam gasket between the motor & clutch housing .
V4f
V4F is offline   Reply With Quote
Old 07-01-2014, 03:58 PM   #9
ericr
ericr's Avatar
the whole concept of a design where any part of the rear main bearing is placed outside of the engine pan sounds bizarre to me.....I believe the Company changed that design after the Model "A", didn't it?
ericr is offline   Reply With Quote
Old 07-01-2014, 06:22 PM   #10
Gunmetal blue2
Gunmetal blue2's Avatar
Wish you guy's could get it right, it don't leak oil it just marks its spot. [LOL]
Gunmetal blue2 is offline   Reply With Quote
