Old 05-11-2014, 07:28 PM   #1
Vanspeed
Vanspeed's Avatar
Default Electric fuel pump question
I picked up an electric fuel pump for my model t bodied a chassis. I bought it from macs. It said replacement for ford model a's, 6 volt. I got it and I am ready to install it but the directions say to wire it negative ground. Will this pump work with the stock positive ground electrical system?
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 05-11-2014, 07:44 PM   #2
machine girl
Default Re: Electric fuel pump question
one time we had one like that pumped the fuel backwards try an air tex 8902 2.5-4 psi
machine girl is offline   Reply With Quote
Old 05-11-2014, 08:30 PM   #3
Vanspeed
Vanspeed's Avatar
Why not just turn it around then?
Old 05-11-2014, 08:31 PM   #4
Vanspeed
Vanspeed's Avatar
This is a carter 2-4 psi pump.
Old 05-11-2014, 09:55 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Is it a motor driven pump, or is it a solenoid type pulsing pump?
The ground polarity would matter on the motor driven pump, but shouldn't matter on the pulse type unless it has a diode across the contacts to keep the arcing to a minimum.
Old 05-11-2014, 10:03 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Try giving Mac's a call. I would think if it made no difference it would not mention polarity in the instructions.
Old 05-12-2014, 10:40 AM   #7
Vanspeed
Vanspeed's Avatar
It does not appear to be a motor driven pump. I will try calling them.
Old 05-12-2014, 11:00 AM   #8
howie123
howie123's Avatar
Vanspeed, I have the same fuel pump on my Model A speedster. I remember having the same question after reading the instructions. I even contacted the manufacturer with no response. Bottom line, the car is positive ground so I hooked up the pump with positive to ground. It works well. I did try it without a regulator but the pressure was still too high. I got a Holley regulator and turned it down to about 1 psi. I've had no problems with the pump. Hope this helps. Howie
howie123 is offline   Reply With Quote
Old 05-12-2014, 05:34 PM   #9
Vanspeed
Vanspeed's Avatar
That is good news, i have read somewhere that as long as it's isolated, it will work either way. Hope it does.
Old 07-03-2014, 09:50 PM   #10
CheaterBobber
CheaterBobber's Avatar
When wiring the fuel pump can you run the positive lead from pump to ignition switch?
Thanks
CheaterBobber is offline   Reply With Quote
Old 07-03-2014, 10:58 PM   #11
Tom Wesenberg
Thanks
No, the ignition switch is the ground side of the coil, so nothing should be connected to it.
Old 07-04-2014, 01:34 PM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
"Maybe" he has his switch set up as a "HOT" switch.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-04-2014, 03:52 PM   #13
denis4x4
denis4x4's Avatar
I have a couple of A's with electric fuel pumps and I have them wired through a switch so when I'm setting the timing or some such thing, I can turn the pump off.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 07-04-2014, 09:32 PM   #14
CheaterBobber
Ignition cable and ground to other post. That's why I thought could run positive fuel pump to positive ignition cable.
Thoughts
Old 07-06-2014, 04:12 PM   #15
Vanspeed
Vanspeed's Avatar
I got it working, I wired the positive side of the pump to the the chassis and ran the negative lead to a toggle switch on the dash, then from the toggle switch to the terminal box. It works well, you just have to remember to turn the toggle switch on which is no big deal to me. Very happy with it so far.
