Old 07-01-2013, 10:57 AM   #1
keith oh
keith oh's Avatar
Question Ansco MMO oiler
Would like to see pictures of how you mounted your MMO oiler especially in 35-36 Ford.
keith oh is offline   Reply With Quote
Old 07-01-2013, 04:56 PM   #2
G.M.
Default Re: Ansco MMO oiler
I purchased 6 or 8 of the Amsco oilers when they guy selling hem first got them. Also have several MMO oilers installed. They all work good. Attached are a few of the Amsco units. G.M.
www.fordcollector.com
Old 07-01-2013, 06:52 PM   #3
flatheadfan
flatheadfan's Avatar
Keith-
I have a '35 with an oiler. Locating the oiler had a self-imposed problem. I did not want to drill any holes in the firewall or the frame. To get around this I used the two bolts that hold my radio. I made a metal horizontal strip that reached from one radio bolt to the other. Next, I made two metal strips attached to the horizontal strip that were bent downard following the profile of the firewall. On the ends of these strips I made another horizontal strip where I mounted the oiler. On the backside of this strip I used some self-sticking high density rubber. As you can see in the picture I also use this same bracket to mount my voltage regulator. No problems with this insulation and it has been on there for several years.
Tom
flatheadfan is offline   Reply With Quote
Old 07-01-2013, 07:46 PM   #4
oldford2
oldford2's Avatar
I have one on our 46. Takes some trips to get the "feed rate" set. The level goes down in mine about 1/4" in 100 miles. I also pour about 4 oz. in the tank when I gas up (8 gallons). This way it goes thru the inside of the carb. Seems to work fine. If mounted on the firewall, be sure to make a coil in the line to the carb to dampen vibration between the unit and the engine.
John
oldford2 is offline   Reply With Quote
Old 07-01-2013, 07:51 PM   #5
keith oh
keith oh's Avatar
Thank you gentlemen, The pictures help. A bracket useing my Volt. Reg. holes will keep from drilling any more holes. Also it looks like, from Flatheadfan's picture, that it doesn't matter if the bottle is below the carb. level. I think I can T into the vacuum plate line that is there for a gasolene heater. Keith oh
Old 07-01-2013, 09:53 PM   #6
G.M.
You could also mount it from the radiator rods. G.M.
Old 07-02-2013, 08:06 AM   #7
36tbird
This is my solution. I made a bracket to be symmetrical with the oil filter canister. I am trying to "busy up" the engine compartment.
36tbird is offline   Reply With Quote
Old 07-02-2013, 10:06 AM   #8
TagMan
I think you succeeded !!
TagMan is offline   Reply With Quote
Old 07-02-2013, 12:09 PM   #9
40cpe
40cpe's Avatar
tbird, I sent you a PM.
40cpe is offline   Reply With Quote
