Old 07-01-2014, 10:34 AM   #1
keith oh
keith oh's Avatar
Default Uncle Max day--Fumble finger me
Had Uncle Max rebuild my 97, what a beautiful Job. Only a fumble finger like me could mess up a nice new carb day by somehow dropping a nut down the manifold when replacing it. After trying all the magnet retrieval attempts to no avail, I spent a couple of hours removing the manifold and there it was on top of the #4 cyl. valve spring. Moral to story, Don't store the nuts on the studs especially if you have 82 year old fumble fingers.
At least I mustered the guts to admit it.
keith oh is offline   Reply With Quote
Old 07-01-2014, 10:52 AM   #2
Mart
Mart's Avatar
Default Re: Uncle Max day--Fumble finger me
Glad you were able to find it. Is the washer accounted for?
Mart.
Old 07-01-2014, 11:45 AM   #3
Willit Stop
Willit Stop's Avatar
Could've happened to anyone.....Murphy's law.I've always been amazed how far things can travel when dropped and where they wind up. Has anyone seen my vacuum brake spring?
Willit Stop is offline   Reply With Quote
Old 07-01-2014, 12:12 PM   #4
JSeery
JSeery's Avatar
Ok, trying to follow this one. How can you drop a nut down the intake manifold and find it on a valve spring! I understand the dropping part, do it all the time myself, just don't understand the path from the intake manifold to the valve spring, they're not connected. The manifold leads to the inside of the cylinders and valve springs are located in the valley under the manifold. What am I missing here?
Old 07-01-2014, 12:22 PM   #5
Ronnie
Ronnie's Avatar
Me too!!!!! That is a bit of a stretch.
R
Ronnie is offline   Reply With Quote
Old 07-01-2014, 12:30 PM   #6
Ross F-1
Ross F-1's Avatar
I'd assume it fell out of the manifold onto the spring when he pulled the manifold.
I no longer use washers on the carb studs for this very reason...
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-01-2014, 02:25 PM   #7
keith oh
keith oh's Avatar
I Don't know but there it was, maybe because you have to turn the manifold every way but loose to get it past this and that on the way out. By the way, where the hell do you think those passages lead to on the way past the valve spring, by the valve into the cylinder, JSeery and Ronnie?
Old 07-01-2014, 02:49 PM   #8
JSeery
JSeery's Avatar
LOL, It sure isn't past the value springs!!! The intake passage goes through the block ports into the valve pockets under the valve heads. The stem of the valve goes through the valve guides into the valley under the intake. The springs are held on the valve stems by the retainers and keepers. If anything can get from the intake ports into the valley where the springs are you've got big problems!!!
Old 07-01-2014, 02:56 PM   #9
JSeery
JSeery's Avatar
Do any of these diagrams help?
Old 07-01-2014, 02:57 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
As seen in the pic, valve springs are in an entirely different chamber, that IS NOT accessible via the intake manifold runners. Your gyrations probably dumped it from an intake runner into the chamber where the springs are located when you removed the intake. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-01-2014, 02:57 PM   #11
JSeery
JSeery's Avatar
I can look for a more detailed view of the passages if you are interested?
Old 07-01-2014, 03:04 PM   #12
JSeery
JSeery's Avatar
Found a view of the intake passage but it does not show the spring. In the passage drawing you can see that the value guides both support the valve and provide a seal between the intake port and the engine valley.
Old 07-01-2014, 03:07 PM   #13
JSeery
JSeery's Avatar
Well, that wasn't the drawing I wanted! It's ok, but doesn't show much of the guide.
Old 07-01-2014, 03:18 PM   #14
hardtimes
hardtimes's Avatar
Hey DD,
X2...Pretty easy to deduce this ,eh !
Matter of fact, with gyrations as you explained...I'd like to see someone explain how it wouldn't end up as Keith explained ?
Keith, You done good for octogenarian , eh ! I've had several ops on each hand to 'help' add to age thing..no complaints tho, just saying that you've got good reason...Murthy be damned !
Oh, btw, had Max to two 81s for me....they were so purty that I don't have the heart to use and get them dirty. So, they set where I can look at them time/time..with other jewels !
Old 07-01-2014, 04:14 PM   #15
Mart
Mart's Avatar
He found the nut. Why get all twisted up? He's 82 years old and working on his car and solving problems.
Power to ya Keith.
Old 07-01-2014, 10:19 PM   #16
JSeery
JSeery's Avatar
Power to ya Keith.
Not sure what that is about, trying to help the guy out. Thought he ask a question about why the value springs were not in the intake port path and was attempting to provide him some diagrams. I appreciate it when others provide me information on questions I have.
Old 07-02-2014, 03:07 AM   #17
Mart
Mart's Avatar
It seemed more of an exercise in trying to prove he was mistaken.
If I misread it, I apologise.
Mart.
Old 07-02-2014, 03:10 PM   #18
keith oh
keith oh's Avatar
No problem folks, I enjoy a little humor and have very thick skin.....
