Old 05-09-2021, 09:09 AM   #1
Res731
Res731's Avatar
Default Rear carrier warped
I believe the rear emergency brake carrier is warped on my 1931. Is it possible to fix this or is it a replace only? I have earlier bands without the tabs available, are these ok to use or do I need tabbed ones and can you mix them on different sides left/right?
Many thanks
Res731 is offline   Reply With Quote
Old 05-09-2021, 04:34 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Rear carrier warped
https://www.fordbarn.com/forum/showt...+brake+carrier
This is what happens when you try to use your e brake to stop your car at road speeds. Is this what happened to yours?
Mike Peters is offline   Reply With Quote
