Old 05-08-2021, 07:17 AM   #1
barrelnose
Default Marvel Schebler carb question
Can anyone tell me what the Model 10-2929 is/was used on, its a single barrel carb.
I read that the 10-2928 Model was used as a replacement on the 34-40 v8s but cannot find any info on the 2929 Model.
Any help would be appreciated, also a cfm rating if known.
The one I have(2929) was used on an A model motor out of an old race car and are trying to sort the difference using this opposed to a 94 or 97 carb.
barrelnose is offline   Reply With Quote
Old 05-08-2021, 09:02 AM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Marvel Schebler carb question
Google keywords "10-2929" & "carburetor". Something useful might pop up..Jack E/NJ
Old 05-08-2021, 09:59 AM   #3
barrelnose
Leads me to eBay adds with info I’m not convinced the sellers really know.
Old 05-08-2021, 10:45 AM   #4
rotorwrench
rotorwrench's Avatar
Marvel Schebler, a division of Borg Warner, supplied carbs to all sorts of manufacturers before they went completely over to aviation type carbs. They were in the automotive aftermarket business too. A lot depends on what type of base it has. The ones in the flea-pay adds have a universal 2-venturi type base that would fit a lot of different engine models with all the different pattern bolt holes they have.
The Ford G series 226 used a single venturi carburetor as well as the H series later but they had the single venturi base and I'm sure they came with Holley types. It wouldn't make much sense to put a single venturi carb on a V8 unless it was for multi carb applications.
My 1956 Ford 850 tractor has a Marvel Schebler on it but it's an updraft type single venturi carb.
Old 05-08-2021, 11:03 AM   #5
Jack E/NJ
Jack E/NJ's Avatar
Looks like some of the 1-bbl carbs have base adapters that fit 2-bbl intake manifolds. Probably a marketing ploy back in the day to replace those huge 2-bbl fuel hogs..Jack E/NJ
Old 05-08-2021, 07:15 PM   #6
barrelnose
Thanks for the replies, A carby specialist on another forum stated it’s an after market paperweight. Basically a throw away spare part. I’ll run with that.
Old 05-08-2021, 08:56 PM   #7
Jack E/NJ
Jack E/NJ's Avatar
So does this mean you're gonna try to run with an after-market throw-away 1-bbl paperweight instead of a 2-bbl 97 or 94? Should be interesting. Let us know how it goes. Jack E/NJ
Old 05-09-2021, 01:00 AM   #8
barrelnose
Also a later post from the carb specialist, and it does have the adjustable main jet,,
Barrelnose - some of the M/S aftermarket carburetors, while less than ideal in either design or quality of materials; did feature externally adjustable main metering jet(s), which might appeal to a racer.
As you say, we will never know. As he retained the unit, we must assume he was happy with it.
Old 05-10-2021, 07:26 AM   #9
corvette8n
corvette8n's Avatar
My Ford 8n had an updraft Marvel Schebler also, ran ok for what is was designed for.
