05-03-2021, 09:14 AM | #1 |
need a diagram
Did all the changes for 12 volt with new alternator. Putin a 12 volt mini starter made for the model A. Need a diagram to convert to push button start. Have the solenoid in place & the cables from battery to solenoid & solenoid to starter. This is where I'm stuck.
Thanks Lefthander 1930 |
05-03-2021, 09:42 AM | #2 |
Re: need a diagram
Did you not get a wiring diagram w/the starter?
Depending on the solenoid you probably need to run a switched 12V + wire to the small terminal on the solenoid to activate it. Typically a NO (normally open) push button switch would be used. A picture of what you have would help.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 05-03-2021 at 09:43 AM. Reason: Addition |
05-03-2021, 10:08 AM | #3 |
Re: need a diagram
This is a simple diagram
Bob Bidonde |
05-03-2021, 10:28 AM | #4 |
Re: need a diagram
This picture is from Bratton's. |
