Old 04-23-2021, 12:23 PM   #1
Michael_Velling
Default Zenith carb overfloating at Choke GAV - why?
Hello, hope you have an idea. My Zenith Carb is leaking at the Choke-GAV entry (see picture). The float level is set to 5/8 Inch from the bottom. All gaskets are new. But when the carb is in the car or on my test-jig there is fuel in this "tube". After a while it is leaking down to the earth.
Have you an idea how to stop this?
Set the float level lower?
Thanks a lot for help and hope you understand my "english"
Michael
Greetings
Michael
Toenisvorst, Germany
Michael_Velling is offline   Reply With Quote
Old 04-23-2021, 01:16 PM   #2
Ruth
Default Re: Zenith carb overfloating at Choke GAV - why?
Michael
Michael, your English is fine. You say the gas is coming out the top of the tube? Sound to me like your float is too high or the needle valve is not holding. Or is it leaking where the tube is threaded into the body?
Ruth
Old 04-23-2021, 01:58 PM   #3
Tom Endy
Tom Endy's Avatar
The threads in the casting for the GAV assembly and the GAV itself are a pipe thread designed to seal off a leak. However I have encountered castings where someone had ran a regular tap of the same size through it and destroyed the sealing capability of the threads.
I also make it a practice to coat the threads with a pipe sealer. Avoid using Mylar tape as pieces of it may migrate to the cap jet.
The sealer I use is called Gasoila E-seal. I found it on-line, comes in a one pint can and is green in color.
Tom Endy
Old 04-23-2021, 05:38 PM   #4
Gene F
Gene F's Avatar
I bet Tom is right about being retapped by a novice.
Old 04-24-2021, 01:16 AM   #5
Michael_Velling
The thread is okay and not destroyed. Around the casting and the GAV Assembly is everything okay. The fuel is coming from the float bowl through the small hole in the bottom of the bowl to the GAV Needle and then up in the tube. If i screw in the Needle complete there is no leaking. But then the car dont runs.
Greetings
Michael
Old 04-24-2021, 10:50 AM   #6
Brentwood Bob
Try changing the float valve. Could also be a bad float, or bad threads in the casting for the float valve.
Brentwood Bob is offline   Reply With Quote
Old 04-24-2021, 10:51 AM   #7
Michael_Velling
Hi everybody,
changed the float Valve and set the float level a little bit down. Now everything is fine. Have done a road trip 10 Miles / 16 km this afternoon.
Thanks for the help
Greetings
Michael
