04-09-2021, 12:52 PM | #61 |
Re: Engine not starting - checked everything - no more idea
I had the same thing after rebuilding the engine. Everything was OK, but it did not run !
Finally checked the camshaft timing. That was completely wrong, 10% off ! Do check the timing, cam gear dot to the right edge of the crank gear peg. Wish you luck ! Henk
You don’t own a Model A ... it owns you ! |
04-11-2021, 06:36 AM | #62 |
Did you paint the engine and leave tape over the intake and exhaust holes? I did that
04-11-2021, 06:36 AM | #63 |
The car runs fine, tried it for a ride about 25 km - last week. This weekend heavy rain here near the dutch border.
@Henk / Hazelhoff: Did you send the rain? Michael
Greetings Michael ------ Toenisvorst, Germany |
04-11-2021, 08:22 AM | #64 | |
04-11-2021, 11:29 AM | #65 |
I would suspect the gav needle is broke off at the tip ,with a new needle inserted into it. thus working as though the valve was turned all the way in. there beirng no adjustment.
04-12-2021, 05:42 PM | #66 |
04-12-2021, 07:46 PM | #67 |
04-13-2021, 12:39 PM | #68 | |
Grusse, Henk
