Old 02-28-2021, 12:35 PM   #1
mike42
mike42's Avatar
Default Brake Bleeding on 1940 Sedan
Weather is getting nice in Northern Michigan and I'll be out putting on that last rear brake cylinder soon and start the bleeding process again.
Quick question....when bleeding should I leave the Master Cylinder open or close it up with the plug each time I fill it up ?
Thx.... Mike
mike42 is offline   Reply With Quote
Old 02-28-2021, 12:41 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Brake Bleeding on 1940 Sedan
I always replace the plug each time I "pump". Remember, pump slowly.
Old 02-28-2021, 12:43 PM   #3
rbone
You can cap it if you want, but it's not necessary. Just remember to keep the fluid level in the master cylinder high enough so you don't pull any air into the system.
rbone is offline   Reply With Quote
Old 02-28-2021, 08:43 PM   #4
paul2748
paul2748's Avatar
I always put the cap on
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-01-2021, 07:39 AM   #5
Ford Freak
I always put the cap back on . Better to be safe than sorry! - F F
1952 Ford F1
1965 Ford Falcon Sprint
2007 Ford Mustang GT
Ford Freak is offline   Reply With Quote
Old 03-01-2021, 07:51 AM   #6
Mart
Mart's Avatar
Better with cap on, even if only loosely. There can be a little jet of fluid from the recuperation port that can come over the top if not careful.
Old 03-01-2021, 08:40 AM   #7
glennpm
glennpm's Avatar
I agree with Mart. Without the cap on, when you pump it, you'll get fluid all over the place.
Old 03-01-2021, 10:18 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
That is a FACT! Certainly isn't worth the chance of brake fluid on your carpet, or God forbid....on any painted surface!! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-01-2021, 11:58 AM   #9
mike42
mike42's Avatar
Thx guys....appreciate the feed back. Too cold today to start anything. 45º yesterday and 18º today !! That's Northern Michigan for ya !
Mike
Old 03-01-2021, 12:35 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Mike
Monday Feb. 15th (two weeks ago) it was about 18º-ish....a "monumentally Cool" day for us in Houston, for sure. It was that next day (Tuesday 16th) that got us....about 7º or so. That's nippy! Our power was off for 47 hours thru that....NO heat! We're waiting on our insurance adjuster, finally this afternoon, to look at burst pipe damage. Many had it a lot worse than us, for sure. We hit 81º yesterday.
DD
T5 W/TORQUE TUBE
Old 03-02-2021, 07:27 AM   #11
mike42
mike42's Avatar
Coop .....
I feel sorry for you guys down there. My Neighbors brother is having a hell of a time with that storm damage and then to make matters worse he got a HUGE electric bill ! I shouldn't complain about Northern Michigan, but the weather does change day to day pretty quickly here !
Good luck !
Mike
