06-21-2016, 07:55 AM | #1 |
coolant fan
1930 Roadster did they come with a 4 blade fan or 2 blade
06-21-2016, 08:08 AM | #2 |
Re: coolant fan
All stock Model A's came with two-blade fan.
If it has a four-blade, it was a later addition. |
06-21-2016, 09:43 AM | #3 |
Re: coolant fan
ok thank you
had a guy telling me that he thought that all 30-31's came with a 4 blade fan so I thought I would ask tinkirk |
06-21-2016, 10:43 AM | #4 |
Re: coolant fan
Frank is correct but a little more trivia. The 4 blade fan for the four cylinder Ford came out in 1933 (part #46-8600). Ford designated this fan as the replacement fan 1928-34 and that is the reason so many of them are found on Model A's. If I needed a fan today I would buy one of the reproduction aluminum fans. Be sure to buy a new one from a reputable supplier as some of the early ones had problems.
Charlie Stephens |
06-21-2016, 01:17 PM | #5 |
Re: coolant fan
