05-06-2021, 12:26 PM | #1 |
Vega steering box in a 40 Ford PU
Anyone done this ?
05-06-2021, 01:08 PM | #2 |
Re: Vega steering box in a 40 Ford PU
You'd be far better off using a Saginaw "525" box rather than a Vega. A dozen guys are gonna come back saying that the Vega works just fine. But that Vega box WAS engineered for a wimpy, light Vega, and a '40 is a heftier vehicle than a Vega. The "525" is shaped very similar to a Vega, yet is only very slightly larger, and most-definitely rugged enough to handle a vehicle of a 1940's weight. The "525" came in GM mid-size vehicles such as Chevelles and Cutlasses. They're great boxes and can be had in several ratios. Also, the '40 Pitman arms fit the '60s, '70s & '80s "525" spline. And, they can easily be bolted into a '40. Borgeson and many others have all of the adaptive and support pieces you could ask for. DD VEGA Box GM "525" ........ |
05-06-2021, 01:12 PM | #3 |
I used a short input shaft Borgeson 525 box from Pete & Jake's in my 40 coupe and it works great. I used the bolt in frame adapter #5002 from Pete & Jake's to mount it. Also used the P&J 525 pitman arm. Costs no more than a Vega and is much safer
05-06-2021, 01:20 PM | #4 |
If you insist on using a Vega box, it would be a good idea to stay away from the aftermarket boxes. There have been many reports about them failing prematurely.
05-06-2021, 01:38 PM | #5 | |
...............and the real (USED) ones are likely plum 'wore-out'! DD |
05-06-2021, 03:07 PM | #6 |
05-07-2021, 12:10 PM | #7 |
I used one in my 40 Merc sedan, worked and is still working great.
IN GOD WE TRUST - SEMPER FIDELIS John |
05-07-2021, 05:34 PM | #8 |
The Vega works for a T bucket or '32 but as others have stated the Saginaw is a better choice for the heavier '40 Ford.
05-07-2021, 10:06 PM | #9 |
jeeps used 525 also.70's I think. Lares Corp can rebuild if needed
05-09-2021, 06:49 AM | #10 |
Used it in my 47 pU when I converted to cross steering.
Gramps |
05-09-2021, 08:31 PM | #11 |
I’m using a 525 in my pickup.
