05-01-2021, 06:07 AM | #1 |
‘35 gas pedal rod?
On a ‘35 is there supposed to be a grommet or bushing around the gas pedal throttle rod where it goes thru the floor, see red circled in pic. Pic is of a wood floor board mine is metal with same hole I’m speaking of.
Nomad Last edited by AnthonyG; 05-01-2021 at 07:08 AM. |
05-01-2021, 11:41 AM | #2 |
Re: ‘35 gas pedal rod?
I have seen a 2"x2" felt square with a hole punched in the center stapled to the top side of the wooden toeboard. Not sure if that's stock.
05-07-2021, 11:55 AM | #3 |
Maybe a bellows-type rubber piece, like a shifter boot would be correct. I know the 51-52 F1's had something like that.
05-07-2021, 01:28 PM | #4 |
I dont know if its correct but it works , use a master cyl rubber boot . The truck ones are what I use
05-07-2021, 08:17 PM | #5 |
Model A’s send a leather type of material for this. You can find them in the A parts catalogs. I can’t imagine 35’s were much different.
05-08-2021, 10:05 AM | #6 |
Nomad |
