Old 05-04-2021, 07:52 PM   #1
Frosty1
Default 1939 Woody Radiator Installation
I’m installing my radiator back into a 1939 frame. (No fenders mounted yet and I didn’t disassemble the car. I got it in pieces.)
There are 2 pair of holes on the front of the frame where the rad mounts, approximately 1” apart.
Which holes are the correct mounting holes for the radiator? Front or back hole? Does the location matter to the geometry of the fenders/grill when I go to mount them? (I'm thinking of the location for the radiator deflectors.)
Frosty1 is offline   Reply With Quote
Old 05-04-2021, 08:04 PM   #2
Kube
Kube's Avatar
Default Re: 1939 Woody Radiator Installation
Two pair of holes? That isn't correct.
The proper placement will only matter to the fitment of the hoses.
The fenders and grille do not intersect with the radiator. Nor do the air deflectors.
I've attached a photograph of a proper '39 wagon frame.
Old 05-04-2021, 09:27 PM   #3
Frosty1
Thanks Kube. My frame looks like that as far as the ends go, but I have an extra set of holes, set in front of the ones in your frame. I guess it served someone's purpose at one time.
Anyway, it looks like I should be using the rear set of holes for placement.
Cheers, Al
Old 05-04-2021, 10:07 PM   #4
mercman from oz
mercman from oz's Avatar
Great shot of a restored frame showing the Brake Lines etc. Nice.
Old 05-05-2021, 03:59 PM   #5
swoopNZ
MEMBER EMERITUS
May have been for a V8-60.
swoopNZ is offline   Reply With Quote
