Old 04-30-2021, 09:41 AM   #1
Allans
Default Engine mounts
Hello, I am new to this site. I have a 1957 thunderbird that had an engine and tranny swap. It now has a 79 302 in it. Someone fabricated a front engine mount that uses two of the timing cover bolts to hold the engine. It is not adequate. I feel that the side engine mounts are better. What are your thoughts?
Allans is offline   Reply With Quote
Old 04-30-2021, 12:36 PM   #2
evintho
Default Re: Engine mounts
Isn't the 302 timing cover cast aluminum? I would think that's not a very desirable mounting point!
evintho is offline   Reply With Quote
Old 04-30-2021, 01:05 PM   #3
JeffB2
JeffB2's Avatar
1955-57 Thunderbirds share the same suspension as 1954-56 Ford cars thse are the mounts they use here. https://www.jalopyjournal.com/forum/...-mounts.41498/
JeffB2 is offline   Reply With Quote
Old 04-30-2021, 01:22 PM   #4
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Engine mounts
I never thought the BIRD design was adequate for even the FYB.
It has to have side mounts (fabricated) with a crossover tube to tie the rails together (IMO). The mounts Jeff showed are for a sedan I believe but is what final design/install will appear.
FORD took the cheap way out for the mounting as the engine set so far back.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
