04-22-2021, 08:45 AM | #1 |
Starter adjustments?
Since engine refresh & re-install on 8BA my starter bendix gear intermittently dis-engages prematurely letting it run without engagement. Car starts OK but know it shouldn’t disengage & spin freely as described? I have the block-starter support screw installed . Is there more tweaking involved?
Nomad Last edited by AnthonyG; 04-22-2021 at 09:07 AM. |
04-22-2021, 09:13 AM | #2 |
Re: Starter adjustments?
The ring gear is a shrink fit onto the flywheel. If the ring gear was not properly installed, or has moved, that might be a problem keeping the Bendix gear engaged. Otherwise, thoroughly clean and de-gum the shaft and gear on the Bendix.
04-22-2021, 09:38 AM | #3 |
Cleaning and polish the shaft should help. Do not use a grease for it will only serve to collect gunk on the shaft down the road.
04-22-2021, 09:47 AM | #4 | |
04-22-2021, 10:12 AM | #5 |
An additional ground cable might help??? Just a thought... Chap
04-22-2021, 11:04 AM | #6 |
A cold engine or an engine that is flooded will always be a bit problematic to start with the old centrifugal design starter bendix. |
04-22-2021, 03:04 PM | #7 |
Thx for the ideas & information! I do remember it doing it less frequently before engine refresh. Due to surgery took a lot longer to get back together than planned. Probably sat for 1 1/2 yrs. With Info rotowrench gave, I’ll keep using as it always re-engages & hope with use it gets back to where it was.
Nomad |
